Hi i need help witch code down below. Everything works with a single button but i need to have 8 buttons and i cant figure it out. Anyone can help please ?
Thanks.
#include <PJONSoftwareBitBang.h>
const int recieverid = 45; // Address of the reciever to send data
PJONSoftwareBitBang bus(11); // Address of this device
const int button = 2; // Gpio toogle switch pin
unsigned long previousMillis = 0; // Mills time stored when hold pressedd
const long sendingInterval = 200; // Sending interval when hold pressed
int holdCounter = 0; // Counter variable when hold pressed
int holdInterval = 15; // Max counter when hold pressed
int bounceTime = 50; // Debounce time for Gpio pin
int holdTime = 250; // Time after which hold state happends
int doubleTime = 500; // Time which you need to double press
int lastReading = LOW; // Last reading state
int hold = 0; // Hold state
int single = 0; // Single predd state
long onTime = 0; // On time when held
long lastSwitchTime = 0; // Last switch time
pinMode(button, INPUT);
bus.strategy.set_pin(12); // PJON bus pin
bus.begin(); // Start PJON bus
Serial.println("Starting");
Serial.print("PJON - Sender's device id: ");
Serial.println(bus.device_id()); // PJON this device ID
bus.update(); // Update PJON buss
int reading = digitalRead(button);
//////////////////////////////////////////BUTTON LOGIC/////////////////////////////////
//First pressed
if (reading == HIGH && lastReading == LOW) {
onTime = millis();
///////////////////////////Held///////////////////////////
if (reading == HIGH && lastReading == HIGH) {
if ((millis() - onTime) > holdTime && holdCounter < holdInterval) {
if (currentMillis - previousMillis >= sendingInterval) {
bus.send(recieverid, "1C", 2);
hold = 1;
holdCounter++;
Serial.println("Holding | Send C");
///////////////////////////Released///////////////////////////
if (reading == LOW && lastReading == HIGH) {
if (((millis() - onTime) > bounceTime) && hold != 1) {
onRelease();
if (hold == 1) {
hold = 0;
holdCounter = 0;
Serial.print("Held | holdCounter is: ");
Serial.println(holdCounter);
lastReading = reading;
///////////////////////////Single press///////////////////////////
if (single == 1 && (millis() - lastSwitchTime) > doubleTime) {
bus.send(recieverid, "1A", 2);
single = 0;
Serial.println("Single press | Send A");
void onRelease() {
if ((millis() - lastSwitchTime) >= doubleTime) {
single = 1;
lastSwitchTime = millis();
return;
///////////////////////////Double press///////////////////////////
if ((millis() - lastSwitchTime) < doubleTime) {
bus.send(recieverid, "1B", 2);
single = 0;
Serial.println("Double press | Send B");
