8 ch relay activated by button/switch press, HELP!
Hello Arduino community!
I want to thank anyone taking the time to read this in advance, any help and input is greatly appreciated.
I am working on controlling the 8-channel relay board from Sainsmart with mechanical button/switch presses. I am not getting the results I am looking for.
Below is what I got when I stopped writing the code.
wBest regards,
Yost
AD 1.0
May 20, 2013
Written by Darryn Yost
UNO board
This project is to activate separate relays via the press of 6 different button/switch to trigger different relays.
I am using an UNO and I have used 6 analog pins as inputs from buttons/switches.
Relays are output from digital pins 2 through 9.
// these constants won't change. They are the
// pins used
const int btnPin_UP = (14);      // up button
const int btnPin_DOWN = (15);    // down button
const int btnPin_ONE = (16);      // up button
const int btnPin_TWO = (17);    // down button
const int btnPin_THREE = (18);      // up button
const int btnPin_SET = (19);    // down button
  pinMode(btnPin_UP, INPUT);
  pinMode(btnPin_DOWN, INPUT);
  pinMode(btnPin_ONE, INPUT);
  pinMode(btnPin_TWO, INPUT);
  pinMode(btnPin_THREE, INPUT);
  pinMode(btnPin_SET, INPUT);
  // initialize serial communication:
  //  declare button state then
  // read the BUTTON:
int UP_State = digitalRead(btnPin_UP);
//delay(10);
int DOWN_State = digitalRead(btnPin_DOWN);
//delay(10);
int ONE_State = digitalRead(btnPin_ONE);
//delay(10);
int TWO_State= digitalRead(btnPin_TWO);
//delay(10);
int THREE_State= digitalRead(btnPin_THREE);
//delay(10);
int SET_State= digitalRead(btnPin_SET);
//delay(10);
  Serial.println("btn_UP  " );
  Serial.println(UP_State);
  Serial.println("btn_DOWN");
  Serial.println(DOWN_State);
  Serial.println("btn_ONE  " );
  Serial.println(ONE_State);
  Serial.println("btn_TWO");
  Serial.println(TWO_State);
  Serial.println("btn_THREE  ");
  Serial.println(THREE_State);
  Serial.println("btn_SET");
  Serial.println(SET_State);
  //  trying to use LED to simulate relay ON/OFF
if(UP_State == 0){
  digitalWrite(12, HIGH); //  Blink LED
  delay(100);
  digitalWrite(12, LOW);
  delay(100);
  delay(100);
  digitalWrite(2, LOW); //  Relay
  delay(2100);
  digitalWrite(13, HIGH);
  delay(2100);
  digitalWrite(13, LOW);
  Serial.println("btn_UP = " );
  delay(2100);
  else if(DOWN_State == 0){
  delay(100);
  delay(100);
  delay(100);
  digitalWrite(3, HIGH); //  Relay
  delay(2000);
  digitalWrite(3, LOW);
  delay(2000);
  delay(2100);
  else if(ONE_State == 0){
  delay(100);
  delay(100);
  delay(100);
  digitalWrite(4, HIGH); //  Relay
  delay(2000);
  digitalWrite(4, LOW);
  delay(2000);
  Serial.println("btn_ONE");
  delay(2100);
  else if(TWO_State == 0){
  delay(100);
  delay(100);
  delay(100);
  digitalWrite(5, HIGH); //  Relay
  delay(2000);
  digitalWrite(5, LOW);
  delay(2000);
  delay(250);
  else if(THREE_State == 0){
  delay(100);
  delay(100);
  delay(100);
  digitalWrite(6, HIGH); //  Relay
  delay(2000);
  digitalWrite(6, LOW);
  delay(2000);
  Serial.println("btn_THREE");
  delay(250);
  else if(SET_State == 0){
  delay(100);
  delay(100);
  delay(100);
  digitalWrite(7, HIGH); //  Relay
  delay(2000);
  digitalWrite(7, LOW);
  delay(2000);
  delay(250);
  delay(10);        // delay in between reads for stability
What results ARE you getting?
Have you tested the relays by themselves??
Take a look at the http:// ArduinoInfo.Info WIKI here: http://arduino-info.wikispaces.com/ArduinoPower#4-8 Try that quick test on 4 of your relays...
