hi, my name is jordy. i'm quiet new in arduino and only taught the basic of C++ from my old teacher. i have a physics project. i want to make a bluetooth controlable relay with arduino. i've tried some code for turning it on and off.
at first, it can't work with more than 2 relay. then, i found out that i forgot to use 'else if' statement, so i change it. after that, it work fine for controlling 3 relay. then, i decide to add all the other 5 relay. it failed. the arduino can't receive my code. i use:
q = Relay 1
w = Relay 2
e = Relay 3
r = Relay 4
t = Relay 5
y = Relay 6
u = Relay 7
i = Relay 8
it can only receive my 'q' input. i use 'else' to control relay 8. so this is my if statement:
q = Relay 1
w = Relay 2
e = Relay 3
r = Relay 4
t = Relay 5
y = Relay 6
u = Relay 7
else = Relay 8
everytime i input other alphabet beside 'q', the arduino read my input as 'else' so it's not w/e/r/t/y/u.
i attach my 3 relay code. can someone please check this code? what did i miss?
Thanks a lot for your answer. I really appreciate that.
int r1 = 2;
int r2 = 3;
int r3 = 4;
int r4 = 5;
int r5 = 6;
int r6 = 7;
int r7 = 8;
int r8 = 9;
pinMode(r1,OUTPUT);
pinMode(r2,OUTPUT);
pinMode(r3,OUTPUT);
pinMode(r4,OUTPUT);
pinMode(r5,OUTPUT);
pinMode(r6,OUTPUT);
pinMode(r7,OUTPUT);
pinMode(r8,OUTPUT);
digitalWrite(r1,HIGH);
digitalWrite(r2,HIGH);
digitalWrite(r3,HIGH);
digitalWrite(r4,HIGH);
digitalWrite(r5,HIGH);
digitalWrite(r6,HIGH);
digitalWrite(r7,HIGH);
digitalWrite(r8,HIGH);
if (Serial.available()) {
delay(100);
while (Serial.available() > 0)
if((Serial.read())=='q')
if(digitalRead(r1)==HIGH)
digitalWrite(r1,LOW);
Serial.println("Turned ON!");
Serial.println("Turned OFF!");
else if((Serial.read())=='w')
if(digitalRead(r2)==HIGH)
digitalWrite(r2,LOW);
if(digitalRead(r3)==HIGH)
digitalWrite(r3,LOW);
}NN
BLUETOOTHH.ino (1.3 KB)
