Hi
I'm looking for a digital potentiometer similar to the AD5206, but has 8 channels of output available.
Does anyone know of one that is arduino controllable and doesn't cost a fortune? I'm not having much luck finding one at the moment.
Thanks
Hi
Thanks
zzygan:
HiI'm looking for a digital potentiometer similar to the AD5206, but has 8 channels of output available.
Thanks
6 channels is quite a lot for a digipot, most are single, dual, or quad. Never seen an 8 and can't search one. Does size/connection count matter that much for your project that you need to shave off one or two packages?
Couldn't you use a pair of AD5204 together with a bit of simple logic which directs the commands to either chip A or chip B
Multiplexing. Of course. Thats the way to do it.
I'm new to this physical computing thing. No problems with the software, just the electronic side of things is quite confusing at the moment.
