8-digit 7-segment max7219
Hello!
I have just bought 8-digit 7-segment module and I would like to use it to display the score of game. So how to connect it to arduino and what is the simplest code to do that?
http://playground.arduino.cc/Main/MAX72XXHardware
What code I should use?
Give us a link to the display you purchased.
Is this to display 1 or 2 players/teams?
What does the score increment by?
https://m.banggood.com/MAX7219-Red-8-Bit-Digital-Tube-LED-Display-Module-For-Arduino-MCU-p-907849.html?rmmds=myorders
Game would be some kind pinball, where targets work like pushbuttons; when ball hits target, current flows trough circuit and arduino reads it with digitalRead function and adds certain score to total points and 8 digit 7 segment display total score.
Here is an example you can start with:
//An example showing how to increment/decrement an 8 digit, seven segment, display.
//LarryD
//Version
//1.00      working code May 13, 2017
#include <SPI.h>
  Arduino pins      MAX7219 pins
  SS     10         LOAD  12
  MOSI   11         DIN   1
  MISO   12         No Connection
  SCK    13         CLK   13
const byte incSwitch = 2; //increment switch, pushed = LOW
byte lastIncSwitchState;
const byte decSwitch = 3; //decrement switch, pushed = LOW
byte lastDecSwitchState;
byte dp = 0;
unsigned long timer1;
unsigned long currentMillis;
unsigned long SwitchMillis;
unsigned long debounceMillis = 100UL;
unsigned long num   = 00000000ul;
//unsigned long num = 99999990ul;    //Use this for testing over flow condition
unsigned long nbr   = 99999999ul;    //(8 digits) largest number before overflow
//unsigned long nbr =  9999999ul;    //(7 digits) largest number before overflow
//7219 registers               Register addresses
const byte MAX7219_REG_NOOP        = 0x0;
// codes 1 to 8 are the digit positions
const byte MAX7219_REG_DECODEMODE  = 0x9;
const byte MAX7219_REG_INTENSITY   = 0xA;
const byte MAX7219_REG_SCANLIMIT   = 0xB;
const byte MAX7219_REG_SHUTDOWN    = 0xC;
const byte MAX7219_REG_DISPLAYTEST = 0xF;
void setup ()
  pinMode (10, OUTPUT);   //set up SS pin 10
  digitalWrite(10, HIGH); //disable the 7219
  SPI.begin ();
  clear7219();
  pinMode(incSwitch, INPUT_PULLUP);
  pinMode(decSwitch, INPUT_PULLUP);
  SwitchMillis = millis();
} //                     End of setup()
void loop ()
  //save the current time
  currentMillis = millis();
  //  //example of automatic counting
  //  if (micros() - timer1 >= 10000)
  //    timer1 = micros();
  //    num++;
  //    displayNumber(num);           //display the new number
  if (currentMillis - SwitchMillis >= debounceMillis)
    //code here runs every debounceMillis ms
    //get ready for the next iteration
    //go and check the switches
    checkSwitches();
}//                        End of  loop()
//                           FUNCTIONS
//switches are checked every debounceValue milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void checkSwitches()
  //re-usable for all the switches
  boolean thisState;
  //check if the increment switch has changed state
  thisState = digitalRead(incSwitch);
  if (thisState != lastIncSwitchState)
    //update the switch state
    lastIncSwitchState = thisState;
    //this switch position has changed so do some stuff
    //"HIGH condition code"
    //switch went from LOW to HIGH
    if (thisState == HIGH)
      //Do some HIGH switch stuff here
    //"LOW condition code"
    //switch went from HIGH to LOW
      num++;
  } //END of incSwitch code
  //check if the decrement switch has changed state
  thisState = digitalRead(decSwitch);
  if (thisState != lastDecSwitchState)
    lastDecSwitchState = thisState;
      if (num != 0)
        num--;
  } //END of decSwitch code
} //                    END of checkSwitches()
// function to display up to eight digits on a 7-segment display
void displayNumber( unsigned long myNumber)
  unsigned long number = myNumber;
  for (byte digit = 1; digit < 9; digit++)
    byte character = number % 10;  // get the value of the rightmost decade
    //replace leadings 0s with blanks
    if (number == 0 && digit > 1)
      character = 0xF;  //value needed to blank a 7221 digit
    //turn on the decimal point to act as a comma if number is > 999 or >999999
    if ((digit == 7 && myNumber > 999999) || (digit == 4 && myNumber > 999))
      //add a dp
      character |= 0b10000000;
    //if we have overflowed the maximum count turn on all the dp to indicate this
    if (myNumber >= nbr)
      // this adds the dp at overflow
    sendByte (9 - digit, character);
    number = number / 10;            //remove the LSD for the next iteration
}//                         End of displayNumber
// Clear the bubble display
void clear7219()
  //SPI.setBitOrder(MSBFIRST);              // MAX7219 requires most significant bit first
  sendByte (MAX7219_REG_SCANLIMIT, 7);      // show 8 digits zero relative
  sendByte (MAX7219_REG_DECODEMODE, 0xFF);  // in the MSD use bit patterns not digits
  sendByte (MAX7219_REG_DISPLAYTEST, 0);    // no display test
  sendByte (MAX7219_REG_INTENSITY, 0x9);    // character intensity: range: 0 to 15
  sendByte (MAX7219_REG_SHUTDOWN, 1);       // not in shutdown mode (ie. start it up)
  //num = 0UL;                                // clear the digits. Leading 0s will be blanked.
  displayNumber(num);
}//                         End of clear7219()
//configure the 7219
void configure (const char mode)
  // Change next line to 0xFF if you want all positions to display a number
  sendByte (MAX7219_REG_DECODEMODE, 0xFF);  // all digits
  sendByte (MAX7219_REG_INTENSITY, 0xA);    // character intensity: range: 0 to 15
}//                         End of configure()
//write a byte to the 7219 register in question
void sendByte (const byte reg, const byte data)
  digitalWrite (SS, LOW);  //enable 7219
  SPI.transfer (reg);      //select the 7219 register
  SPI.transfer (data);     //send the data for this register
  digitalWrite (SS, HIGH); //disable 7219
}//                         End of sendbyte()
//                           END OF PROGRAM
Edit:
Updated code
