I want to build a controller for live playing to control the 16 parts / channels on a synth
2 buttons - Bank A & Bank B
8 faders - Bank A selected is for ch 1 - 8
Bank B selected is for ch 9 - 16
8 buttons - arm / disarm faders
Basically mimicking faders and buttons found on flagship keyboards like the fantom and kronos, control volume for each channel, on the fly mixing of sounds
Is this possible and where do I start?
Thank you!
Start by making a sketch that reads a button. Use the IDE example code.
Yes,
not knowing your skill level
You need to start at the begin, and learn to use one component at the time
- basic Arduino coding (Serial, incl port settings).
- buttons (long short press, debouncing etc)
- faders (min max value, noise handling etc)
- midi communication (uses Serial port
- not using delay() functions for real time interactions
- state machines, to keep control of your system,
- control LEDS (as you want feedback)
- a time planning
- probably more...
If you understand components you can make a design how to combine components and code and gradually build towards the system you want.
Yes, it is possible.
Create and publish a block diagram of your project to identify the physical and logical interfaces.
Thanks everyone, I'm a total noob
Last build i tried back in 2011 was a dj controller from a psp controller using a third party midi software
The physical build I think I can manage to do and source out
8 sliding pots
2 buttons
2 led
Arduino mini
Midi out port
My main concern is the programming
Are there codes ready to use / edit?
Thanks again!
Thanks! I'll check on this!
Here's the final layout
Arduino Mega
1 Midi Out Port
8 sliders for midi channels (1-8 and 9-16)
8 buttons for midi channels (1-8 and 9-16)
1 button for Bank A or B
9 buttons total
8 LED for display On / Off state of buttons
2 LED for display Bank A or Bank B
10 LEDs total
8 buttons to toggle CC 123 for ch 1-16 dependent on Bank Button (A or B)
8 sliders to send CC 07 volume for 1-16 dependent on Bank Button (A or B)
I added the on/off button for CC123 because I don't want to leave all channels on and eat all the polyphony even when the fader for CC07 volume is down to 0
I have yet to try this on tinkercad
I have to learn to program the buttons to toggle on or off for CC123 and the LED state On/Off at the same time
Another thing is the Bank A and B programming (thanks @PieterP for the link
Is the mega the best option for this?
Multiplexer is scaring the heck out of me - extra programming codes
TIA
