8 ohm 0.5 watt speaker interface with arduino
How should I connect an 8 ohm 0.5 watt speaker to arduino uno cause I've heard it can't be connected directly. Please share a simple circuit diagram of how to connect it. Also, is the speaker compatible with talkie library? Basically I just want to make a device which would say the name of the color shown to it for which I have used tcs3200 color sensor and switch case statements. So it would be possible right?
Thank you.
You would need an audio amplifier module and possibly a different power supply. Arduino output pins do not have the capability to drive low impedance loads.
I think the first thing you need to do is read the documentation that is given with the library, GitHub - ArminJo/Talkie: Refurbished Arduino version of the Talkie library from Peter Knight. This has a nice simple schematic with a low pass filter to remove the clicks etc. This will feed an amplifier input. It is also explained how speaker is driven directly by the output of the Arduino, the UNO is one of the ones featured. If you try with the speaker put a flyback diode on the output pin to protect the Arduino. My preference would be to use an amplifier as suggested by jhaine.
But I would guess that it would expect a high impedance speaker as it mentions also a piezo.
Which way round would you put the flyback diode?
Cathode (band) on +. Normally it will not conduct but when it is switched the voice coil (inductor) will reverse polarity and dump its energy wherever it will go. There is no limit on voltage, it is limited by the circuit etc. The diode conducts tis pulse and holds it to 0.7 volts.
Yes the high impedance speaker or headphones would work, that is also in the link or sub links I posted.
Gee thats strange. I'll have to tell my projects to stop beeping their 8 ohm speakers & buzzers.
The simplest solution is regular "powered" computer speakers.
Or, you can buy an amplifier, or an amplifier board, or you can build one from an amplifier chip. (The LM386 is a popular and easy-to-use low-power audio amplifier chip. ) With most amplifiers you'll need an attenuator (or a volume-control pot on the input) because you need little or no voltage gain... You mostly need current & power gain.
Directly to an I/O pin?
Without a driver or amplifier you are "stressing" the Arduino. The "absolute maximum" current from an I/O pin is 40mA. That's a minimum load of 125 Ohms. It might "work" with 8-Ohms but the Arduino might overheat and other "bad things" might happen. It's bad engineering!
5V / 8 Ohms = 625mA. (You won't really get 625mA because the 5V won't hold-up.)
Its been chiming the hours on my mega for close to a year with no issues. maybe because im not playing it continuously? Im feeding the 5v line with a 5v/3a meanwell power supply so there's a ton of solid current avail (average draw is under 1A). I just assumed the pin went into current limit @ 40mA and that was that.
But it wouldn't be very sensible to dc couple the speaker to the pin since it's a DC short. Unless it's a piezo. (And no, it's very unlikely to be 8 ohms at DC, speaker "impedance" is a dodgy concept.)
The links showed a capacitor in series with the speaker. This does the DC coupling. The 8 Ohm is a nominal rating probably at 1 Khz, the impedance changes with the frequency. There is both DC resistance which will be lower than the impedance which is an AC measurement. This link explains that: How To Tell The Impedance of A Speaker - A Guide For Everyone
