Hello,
for a project, I need a long display. But there are none in the size I need (~30mm hight and 150-200mm long)
So I decided to go with 8 of those cheap Oled displays (128x64). They are I²C based and all have the same address. For that reason, I got the TCA9548A, but for some reason, this chip doesn't work as advertised.
If I only have one display connected to the TCA9548A it works, but when I hook up multiple it stops working. Even if I use the same code and don't even try to use the other displays attached.
I also tried different chips and Arduinos just to rule out a defective one. But the same issue.
Does anyone know an alternative to the TCA9548A or maybe knows a cheap display that has the specs I need?
Thanks!
TCA9548A
