8 port relay module, MEGA 2560, Port A, code doesn't stop cycling in void setup
I’m turning on 8 relays at the same time by activating pins 22-29 on an Arduino MEGA 2560 using the port A commands below.
Even when cycling my code for 2 times, and having the usb port plugged into my PC, the code doesn’t stop running.
Am I not turning off my port properly in the void loop?
unsigned long TOn = 4000; // delay time to turn relay on/off (60,000 ms = 1 minute)
unsigned long TOff = 2000;
void setup () {
  DDRA = B11111111; // set PORTA (digital 22-29) to outputs
  int maxnumber = 2; // set cycle count
  for (int count = 0; count < maxnumber;) //Counter will stop counting after certain amount of cycles
    PORTA = B00000000;
    delay(TOn); //relay on time
    PORTA = B11111111;
    delay(TOff); //relay off time
  PORTA = B11111111;
the code doesn't stop running.
How do you KNOW that?
Why is it important that all 8 relays turn on or off at exactly the same time? Seems to me that if you really wanted that, you'd only need one relay.
I think the FOR loop is missing the increment count++.
I’m doing it for mainly future applications
https://www.arduino.cc/en/Reference/PortManipulation
Some reasons:
You may need to be able to turn pins on and off very quickly, meaning within fractions of a microsecond. If you look at the source code in lib/targets/arduino/wiring.c, you will see that digitalRead() and digitalWrite() are each about a dozen or so lines of code, which get compiled into quite a few machine instructions. Each machine instruction requires one clock cycle at 16MHz, which can add up in time-sensitive applications. Direct port access can do the same job in a lot fewer clock cycles.
Sometimes you might need to set multiple output pins at exactly the same time. Calling digitalWrite(10,HIGH); followed by digitalWrite(11,HIGH); will cause pin 10 to go HIGH several microseconds before pin 11, which may confuse certain time-sensitive external digital circuits you have hooked up. Alternatively, you could set both pins high at exactly the same moment in time using PORTB |= B1100;
If you are running low on program memory, you can use these tricks to make your code smaller. It requires a lot fewer bytes of compiled code to simultaneously write a bunch of hardware pins simultaneously via the port registers than it would using a for loop to set each pin separately. In some cases, this might make the difference between your program fitting in flash memory or not!
It was the count++ increment that was missing. :blush: Thanks!
This code below is working:
void setup () {
  int maxnumber = 4; // set cycle count
  for (int count = 0; count < maxnumber; count++) //Counter will stop counting after certain amount of cycles
    PORTA = B00000000;
    PORTA = B11111111;
void loop() {}
