Hi, i tried to use a 8 relay board and i experience some power problem.
If someone can help me to understand my error, it will be great.
This case describe perfectly my connection :
dlloyd:
The first thing to do is ensure you have your relay module connected properly and adequately powered. This example shows how to make use of the optic isolation feature.
INSTRUCTIONS:
Remove blue jumper
Connect JD-VCC and GND from the Relay Module to a Separate 5VDC Supply (1Amp or greater)
Connect VCC from the Relay Module to 5V on your Arduino
Connect required control signals as shown
Note: DO NOT connect GND from the Relay Module to your Arduino
It works perfectly if i activate only 1 to 4 relay simultaneously. And it use near to 250 mA on the dedicate 5VDC.
But if i activate a new relay, it works but after some second, power consumption start to decrise and all relay start to be unstable (LOW / HIGH very quickly).
More relay i activate simultaneouly more quickly the power unstability arrive.
I have tried with two differents mega.
And i have try a L7805C and a LM1117 for the dedicate 5VDC with same result.
leptitlutin:
What input voltage. 9volt, 12volt?
Eight relays could use 880mA = 640mA when active.
If you have used e.g 12volt input for your regulators, then (12-5).640 = ~4.5watt must be dissipated in the regulators. That (getting hot) could shut them down.
Try a 5volt/1Amp phone charger to power the relay card.
Leo..
How much voltage are you feeding into the regulator? Is there a heatsink on the regulator? Have you got capacitors across the regulator as recommended by the datasheet?
The more voltage you "drop" across a (linear) regulator the more heat/power you dissipate. When it gets hot it shuts-down (or "folds back") to protect itself and you can't get the full-rated current.
A switching regulator is much more efficient and it won't heat-up nearly as much. But, it requires an inductor so it's a bit more difficult to build.
Thx
That's what i thought.
But i was thinking to put relay module in a box on my electric panel where i have some other modules power by a "big" 12VDC.
Now i need to find a solution to create a large 5VDC from 12VDC without heating.
