8 RGB LEDs + EXT 5V & ARDUINO
Hi everybody:
I am a new member.
I got some knowledge in electronics and very fascinated with Arduino.
I got this project to illuminate a 3D printer very close to nozzle with 8 RGB LEDs and have light fading into the color very very very slowly.
I've seen how can make work with 1 led, maybe 2 with 220 ohms resistor and 5v with Arduino.
But I want more power!!
I am thinking maybe with external 5v USB supply.
Parallel or serial?
Can you please help me to make it work?
Do I need schematics too?
This de code that I use for long colors fade in one RGB.
#define RED_PIN 9 // where the red pin is connected to
#define GREEN_PIN 10 // where the green pin is connected to
#define BLUE_PIN 11 // where the blue pin is connected to
#define DELAY 1200 // 60ms internal delay; increase for slower fades
pinMode(GREEN_PIN, OUTPUT);
pinMode(BLUE_PIN, OUTPUT);
pinMode(RED_PIN, OUTPUT);
// fade from green to red
for(int i=0; i<255; i++) {
analogWrite(RED_PIN, i);
analogWrite(GREEN_PIN, 255-i);
analogWrite(BLUE_PIN, 0);
delay(DELAY);
// fade from red to blue
analogWrite(RED_PIN, 255-i);
analogWrite(GREEN_PIN, 0);
analogWrite(BLUE_PIN, i);
delay(DELAY);
// fade from blue to green
analogWrite(RED_PIN, 0);
analogWrite(GREEN_PIN, i);
analogWrite(BLUE_PIN, 255-i);
delay(DELAY);
Regards
An Arduino pin (say on a Uno) should not power a device at more than 20mA directly. Can you supply a link to the leds you want to use? These will dictate the power supply requirements and the switching method.
I am gonna use Adafruit
NeoPixel Stick for Arduino- 8 x WS2812 5050 RGB LED
Parallel or serial?
What? That makes no sense.
How else are you going to know what to connect to what?
Are we talking about light or electric power?
You will need a power source capable of giving half an amp of current to turn all those LEDs on full at the same time.
