8 x 7 segments MAX7219 based display not working
Hi all,
I bougth this
[http://www.ebay.es/itm/5V-MAX7219-8-Digit-Display-Rojo-LED-Modulo-7-Segmentos-Tubo-Digital-para-Ard
uino-/400746071949?pt=LH_DefaultDomain_186&hash=item5d4e53c78d](http://www.ebay.es/itm/5V-MAX7219-8-Digit-Display-Rojo-LED-Modulo-7-Segmentos-Tubo-Digital-para-Ard) 8 x 7 segments MAX7219 based
display. I have it wired like "picture1" and try to make it work with this software
/* code for max 7219 from maxim,
reduced and optimised for useing more then one 7219 in a row,
______________________________________
/* ORIGONAL COMMENTS SUPRESSED TO MAKE IT FIT ON THE FORUM (vffgaston 14/11/14)*/
int dataIn = 2;
int load = 3;
int clock = 4;
int maxInUse = 1;    //change this variable to set how many MAX7219's you'll use
int e = 0;           // just a varialble
                     // define max7219 registers
byte max7219_reg_noop        = 0x00;
byte max7219_reg_digit0      = 0x01;
byte max7219_reg_digit1      = 0x02;
byte max7219_reg_digit2      = 0x03;
byte max7219_reg_digit3      = 0x04;
byte max7219_reg_digit4      = 0x05;
byte max7219_reg_digit5      = 0x06;
byte max7219_reg_digit6      = 0x07;
byte max7219_reg_digit7      = 0x08;
byte max7219_reg_decodeMode  = 0x09;
byte max7219_reg_intensity   = 0x0a;
byte max7219_reg_scanLimit   = 0x0b;
byte max7219_reg_shutdown    = 0x0c;
byte max7219_reg_displayTest = 0x0f;
void putByte(byte data) {
  byte i = 8;
  byte mask;
  while(i > 0) {
    mask = 0x01 << (i - 1);      // get bitmask
    digitalWrite( clock, LOW);   // tick
    if (data & mask){            // choose bit
      digitalWrite(dataIn, HIGH);// send 1
    }else{
      digitalWrite(dataIn, LOW); // send 0
    digitalWrite(clock, HIGH);   // tock
    --i;                         // move to lesser bit
void maxSingle( byte reg, byte col) {
//maxSingle is the "easy"  function to use for a     //single max7219
  digitalWrite(load, LOW);       // begin
  putByte(reg);                  // specify register
  putByte(col);//((data & 0x01) * 256) + data >> 1); // put data
  digitalWrite(load, LOW);       // and load da shit
  digitalWrite(load,HIGH);
void maxAll (byte reg, byte col) {    // initialize  all  MAX7219's in the system
  int c = 0;
  for ( c =1; c<= maxInUse; c++) {
void maxOne(byte maxNr, byte reg, byte col) {
//maxOne is for adressing different MAX7219's,
//whilele having a couple of them cascaded
  int c = 0;
  for ( c = maxInUse; c > maxNr; c--) {
    putByte(0);    // means no operation
  for ( c =maxNr-1; c >= 1; c--) {
void setup () {
  pinMode(dataIn, OUTPUT);
  pinMode(clock,  OUTPUT);
  pinMode(load,   OUTPUT);
  //beginSerial(9600);
  digitalWrite(13, HIGH);
//initiation of the max 7219
  maxAll(max7219_reg_scanLimit, 0x07);
  maxAll(max7219_reg_decodeMode, 0x00);  // using an led matrix (not digits)
  maxAll(max7219_reg_shutdown, 0x01);    // not in shutdown mode
  maxAll(max7219_reg_displayTest, 0x00); // no display test
   for (e=1; e<=8; e++) {    // empty registers, turn all LEDs off
    maxAll(e,0);
  maxAll(max7219_reg_intensity, 0x0f & 0x0f);    // the first 0x0f is the value you can set
                                                  // range: 0x00 to 0x0f
void loop () {
  //if you use just one MAX7219 it should look like this
   maxSingle(1,1);                       //  + - - - - - - -
   maxSingle(2,2);                       //  - + - - - - - -
   maxSingle(3,4);                       //  - - + - - - - -
   maxSingle(4,8);                       //  - - - + - - - -
   maxSingle(5,16);                      //  - - - - + - - -
   maxSingle(6,32);                      //  - - - - - + - -
   maxSingle(7,64);                      //  - - - - - - + -
   maxSingle(8,128);                     //  - - - - - - - +
  //if you use more than one MAX7219, it should look like this
  maxAll(1,1);                       //  + - - - - - - -
  maxAll(2,3);                       //  + + - - - - - -
  maxAll(3,7);                       //  + + + - - - - -
  maxAll(4,15);                      //  + + + + - - - -
  maxAll(5,31);                      //  + + + + + - - -
  maxAll(6,63);                      //  + + + + + + - -
  maxAll(7,127);                     //  + + + + + + + -
  maxAll(8,255);                     //  + + + + + + + +
  //if you use more then one max7219 the second one should look like this
  maxOne(2,1,1);                       //  + - - - - - - -
  maxOne(2,2,2);                       //  - + - - - - - -
  maxOne(2,3,4);                       //  - - + - - - - -
  maxOne(2,4,8);                       //  - - - + - - - -
  maxOne(2,5,16);                      //  - - - - + - - -
  maxOne(2,6,32);                      //  - - - - - + - -
  maxOne(2,7,64);                      //  - - - - - - + -
  maxOne(2,8,128);                     //  - - - - - - - +
  delay(2000);
No way (I know it is not for 7 segments, but I guess it should make LEDs lit in some definite
pattern: it either set all LED's on -most of the times- or off: no further functioning).
Then, after rewiring to pins 12, 11 & 10, I tried this software (which is specific for 7 segment pattern)
//We always have to include the library
#include "LedControl.h"
 Now we need a LedControl to work with.
 ***** These pin numbers will probably not work with your hardware *****
 pin 12 is connected to the DataIn
 pin 11 is connected to the CLK
 pin 10 is connected to LOAD
 We have only a single MAX72XX.
LedControl lc=LedControl(12,11,10,1);
/* we always wait a bit between updates of the display */
unsigned long delaytime=250;
   The MAX72XX is in power-saving mode on startup,
   we have to do a wakeup call
  lc.shutdown(0,false);
  /* Set the brightness to a medium values */
  lc.setIntensity(0,8);
  /* and clear the display */
  lc.clearDisplay(0);
 This method will display the characters for the
 word "Arduino" one after the other on digit 0.
void writeArduinoOn7Segment() {
  lc.setChar(0,0,'a',false);
  delay(delaytime);
  lc.setRow(0,0,0x05);
  delay(delaytime);
  lc.setChar(0,0,'d',false);
  delay(delaytime);
  lc.setRow(0,0,0x1c);
  delay(delaytime);
  lc.setRow(0,0,B00010000);
  delay(delaytime);
  lc.setRow(0,0,0x15);
  delay(delaytime);
  lc.setRow(0,0,0x1D);
  delay(delaytime);
  lc.clearDisplay(0);
  delay(delaytime);
  This method will scroll all the hexa-decimal
 numbers and letters on the display. You will need at least
 four 7-Segment digits. otherwise it won't really look that good.
void scrollDigits() {
  for(int i=0;i<13;i++) {
    lc.setDigit(0,3,i,false);
    lc.setDigit(0,2,i+1,false);
    lc.setDigit(0,1,i+2,false);
    lc.setDigit(0,0,i+3,false);
    delay(delaytime);
  lc.clearDisplay(0);
  delay(delaytime);
  writeArduinoOn7Segment();
  scrollDigits();
without success too . . . .(off all the time)
Any idea?
Thanks
(I feel like a noob: Before the #@@ñ#é@##· (f...d, I mean) maintenance weeks ago I was able to
search through the forum by typing the "keywords"; then the related trheads appeared. Now it drives
me to the "google results like" page. I am sorry opening a new trhead -I feel like increasing
universe entropy with no necessity- but I dont know how to find a valuable trhead)
(Picture2 is of the same 7x8 display)
Con't
Of course both GND are tied together. I take 5 V from the arduino (could this be the problem?; I'm feeding currently trhough USB)
Thanks again
This
Does not match the pins you are connecting to in the circuit diagrem.
Both programs are for different connections. I changed pins to test the first or the second- I've tried both cause they use differents approachs (with/without libraries) to (try to) make sure that the display works but, as a friend of mine said, "a man with one watch knows the time. if he has two watches he will never be sure" :wink:
(I keep not knowing whether the display works or not)
Thanks a lot.
OK, forget the stupid libraries.
Here's some proven test code for you.
Just set your pins as:
DIN pin 2
CS (LOAD) pin 3
CLK pin 4
/* Loop scanner demonstration
Code for max 7219 from maxim, reduced & optimised for using multiple 7219 cascaded.
General notes:
- if using only one max7219, then use maxSingle function to control
the module --- maxSingle(register (1-8), column (0-255))
- if using more then one max7219, and all should work the same, use maxAll
function --- maxAll(register (1-8), collum (0-255))
- if using more than one max7219 and want to change something on one module only,
then use maxOne function
--- maxOne(module you want to control [1=first], register [1-8], column [0-255])
 During initiation, be sure to send every part to every max7219 and then upload it.
For example, if you have five max7219's, you have to send the scanLimit 5 times
before you load it, otherwise not every max7219 will get the data. the (fixed)
variable maxInUse keeps track of this, just tell it how many max7219 you are using.
int dataIn = 2;            // "DIN" on module
int load = 3;              // "CS" on module
int clock = 4;             // "CLK" on module
const int ledPin =  13;    // LED pin number
int maxInUse = 1;          // set how many MAX7219's used
int ledState = LOW;        // initialise the LED
  byte i = 8;
  byte mask;
  while(i > 0) {
    if (data & mask) {           // choose bit
// maxSingle is the "easy" function to use for a single max7219
  putByte(col);             //((data & 0x01) * 256) + data >> 1); // put data
void maxAll( byte reg, byte col) {
  int c = 0;
// for adressing different MAX7219's while cascaded
  int c = 0;
    putByte(0);             // no operation
  for ( c = maxNr-1; c >= 1; c--) {
void putCol( byte colno, byte coldat) {
// Interprets colno as (zero ref) index in combined array
    byte t;
    t = colno >> 3;
    byte u;
    u = colno & 0x07;
    maxOne(t+1, u+1, coldat);
void dispon() {
 maxAll(max7219_reg_shutdown, 0x01);               // Display on
void dispoff() {
 maxAll(max7219_reg_shutdown, 0x00);              // Display off
byte irow = 0;          // Row index
byte icol = 0;          // Column index
byte pattern;           // bit mask
byte lcol;              // left border
byte rcol;              // right border
byte trow;              // top row marker
byte brow;              // bottom row marker
int s_vert;             // Vertical switch
int s_horz;             // Horizontal switch
void worker () {
  if (pattern == 0) pattern = trow;            // pattern must be set
  if (s_vert != 0) {
    if (s_vert == -1) {                     // moving upward
      pattern = pattern >> 1;
      if (pattern == trow) {                   // hit the top
        s_vert = 0; s_horz = 1;
      pattern = pattern << 1;               // moving downward
      if (pattern == brow) {                // hit the bottom
        s_vert = 0; s_horz = -1;
    putCol(icol,pattern);              // Show the column.
    return;
  if (s_horz != 0) {
    putCol(icol,0);                    // blank previous column.
    if (s_horz == -1) {                     // moving left
      icol--;
      if (icol == lcol) {                      // hit the side
        s_horz = 0; s_vert = -1;
      icol++;                               // moving right
      if (icol == rcol) {                      // hit the side
        s_horz = 0; s_vert = 1;
// the follow variable is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 60;           // interval at which to step (milliseconds)
long previousMillis = 0;      // will store last time LED was updated
void setup () {
  pinMode(ledPin, OUTPUT);
  //Serial begin(9600);
  maxAll(max7219_reg_scanLimit, 0x07);   // all columns in use
  maxAll(max7219_reg_decodeMode, 0x00);  // using a LED matrix (not digits)
    maxAll(e,0);
  maxAll(max7219_reg_intensity, 0x08 & 0x0f);  // middle argument is intensity value
  pattern = 0;
  s_vert = 0;
  s_horz = 1;
// define edges of loop
  lcol = 0;              // left border
  rcol = 7;              // right border
  trow = 0x01;           // top row marker
  brow = 0x08;           // bottom row marker
void loop () {
// Active waiting for next event
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW) { ledState = HIGH;  } else { ledState = LOW; }
    // Timed process:
    worker();
    // set the LED according to ledState:
    digitalWrite(ledPin, ledState);
The link you posted for the display is broken. It is actually this.
Paul,
Thank you very much. I have just test the module with your code: it does not work, so I have to deduct that the unit is defective.
I'm going to order other unit. I'll test it with your code.
Thanks again.
Regards.
