Is it possible to use one 868Mhz transceiver connecting to several receivers simultaniously?
yes
Depends what you mean by 'connecting' really.
For sure several recievers can all receive the same transmission simultaneously.
That's exactly what I wanted to know. Thanks.
If your so-called receivers send an acknowledgment back to the "transmitter", then that won't work because the acknowledgments at the same time will mean none are received by your "transmitter".
