86Duino is an open-source embedded platform based on Vortex86EX SoC, easy-to-use hardware and software integrated. This Arduino-compatible board can support many x86 O/S as well as those running on the original Arduino base system.
The 86Duino is a high performance and fully static 32-bit x86 processor board compatible with Windows OS, Linux and most popular 32-bit RTOS. It integrates PCIE bus, DDR3, ROM controller, xISA, I2C, SPI, IPC (Internal Peripheral Controllers with DMA and interrupt timer/counter included), Fast Ethernet, FIFO UART, USB2.0 and SD/SATA controller within a single package to form a system-on-a-chip (SOC).
Technical specification
Processor Vortex86EX
Clock Speed 300 MHz
Memory 128MB DDR3
Flash Memory 8MB
Digital I/O Pins 14 (of which 7 provide 32bit PWM output)
Analog Input Pins 6 (11bit)
Operating Voltage 5V
Input Voltage (recommended) 7-12V
DC Current per I/O Pin 16 mA
DC Current for 3.3V Pin 400 mA[/li][/list]
