Hello All.
I am working on creating a bluetooth module for a GameBoy Advanced. I am utilizing a nRF52840 chipset and am looking for some advice.
The module should have 2 main modes, transmitting the analog audio signal to a pair of earbuds, or passing it through to the speaker when no earbuds are connected. The latter is where I could use some feedback.
I plan to pull the signal off of the pins of the 3.5mm jack, and replace the jack with a momentary switch which will send commands to the bluetooth controller (pair, unpair, mute, etc).
The pinout of the jack is as follows:
When no headphones are inserted, input/ouput are shorted, passing sound to the speaker. I would like to mimic this functionality in my module.
So, is my best implementation going to be creating a passthough in code, allowing input and output to flow through the arduino, or should I find some relays and just use an enable signal?
I know the former will have poor audio quality due to switching noise, but what will actually be introduced? will i hear switching hum, or just a poor sample rate? Should I care about sample rate when i have 8bit sound anyway?
If the relay option is preferred, can anyone make a recommendation for a component? I'd like to go as small as I can.
Thanks!
