Hello,
I'm trying to archive a pwm resolution >8bit (10bit or 16bit) on a Leonardo.
I read that the leonardo Timer 1 has 16bit resolution and is used for pine 9 and 10.
After reading through the http://arduino.cc/en/Tutorial/SecretsOfArduinoPWM i know i should set
OCR1A to the desired level (1023 for 10bit resolution).
But wont this affect the frequency aswell?
The timer has to count till 1023 now instead of 255, so the pwm frequency will be 1/4 of the original value, correct?
So what do i have to change to only change the pwm resolution?
On the secrets of pwm page, they provide some code examples.
Adapted the 'Fade' example to this
int led = 9; // the pin that the LED is attached to
int brightness = 0; // how bright the LED is
int fadeAmount = 1; // how many points to fade the LED by
//Pin 13 , 8, 3
//Timer 1, 3, 4
void setup(void)
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
TCCR1A = _BV(COM1A1) | _BV(COM1B1) | _BV(WGM11) | _BV(WGM10);
TCCR1B = _BV(CS12);
OCR1A = 1023;
// set the brightness of pin 9:
analogWrite(9, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness == 0 || brightness == 1023) {
fadeAmount = -fadeAmount ;
// wait for 30 milliseconds to see the dimming effect
delay(100);
The fading seems to work, but the LED on pin 9.
But, the LED flikkers while fading. It seems there are some duty cycles missing in the pwm so the led turns off in between.
(or the frequency is so low it can be seen).
Any help on what needs to be changed?
Thanks!
