Basically what i want is something along these lines
pseudo code
uint8_T = 8_bits_in_register ← this would be the variable that would hold the 8 bits for the register
struct ADMUX ← i know i cannot call it ADMUX but for the sake of making this easier to explain lets say its called admux
some_variable_type left_Adjust ;
some_variable_type ref_Voltage_Avcc ;
some_variable_type ref_Voltage_1v ;
then i would use it :
ADMUX.left_Adjust = true ;
ADMUX.ref_Voltage_1v = false ;
ADMUX.ref_Voltage_AVCC = true ;
and as i set these up they get appended to the 8 bit variable (which would be a binary number)
in the proper order so that when that variable is passed to the register all my setting match
so it would look like
8_bit_variable = 0b00101101 and i would pass that on to the real admux ,
is this feasible? or is there a more efficient way to write a generic way of setting up something such as ADC or PWM for that matter
basically use a structure to set all the bits in a port
i just tried it and seems to work
the names bitZero - bitSeven would be changed to match the register bits such as MUX1 , MUX2, obviously i would have to change it since it cant literally match
and the structure name would be changed to something like ADCsetup …
now it would be ideal if i could initialize the fields to zero so i do not have to set each field to zero , but since this will be a generic reusable file for my self
ill have a function to initialize them all to zero
that way i only set the fields i am interested in
struct testReg
int bitZero ;
int bitOne ;
int bitTwo ;
int bitThree;
int bitFour;
int bitFive;
int bitSix;
int bitSeven;
struct testReg regEdit ; //structure that will represent a register and its settings
uint8_t myVar = 0;
DDRB |= 1<<PINB5 ;
int doTheMath()
// check each field of the structure and weather its true or false add that bit value to the uint8_t
regEdit.bitZero < 1 ? myVar = 0 : myVar = 1 ;
regEdit.bitOne < 1 ? myVar = myVar : myVar +=2 ;
regEdit.bitTwo < 1 ? myVar = myVar : myVar +=4 ;
regEdit.bitThree < 1 ? myVar = myVar : myVar +=8 ;
regEdit.bitFour < 1 ? myVar = myVar : myVar +=16 ;
regEdit.bitFive < 1 ? myVar = myVar : myVar +=32 ;
regEdit.bitSix < 1 ? myVar = myVar : myVar +=64 ;
regEdit.bitSeven < 1 ? myVar = myVar : myVar +=128 ;
return myVar;
void loop ()
regEdit.bitZero = false ;
regEdit.bitOne = false ;
regEdit.bitTwo =false ;
regEdit.bitThree = false;
regEdit.bitFour = false;
//ive set only the 5th bit to true , which i will pass to port B where bit 5 is the led on digital pin 13
regEdit.bitFive = true ;
regEdit.bitSix = false ;
regEdit.bitSeven = false;
PORTB ^= doTheMath();
Serial.println(doTheMath());
delay(50);
Notice how there is a ‘:1’ at the end which specifies that each takes up only a single bit.
You can then do:
volatile BitField* admux = (volatile BitField*)&ADMUX; //declare a BitField variable which is located at the address of ADMUX.
admux->bitZero = 1; //equivalent to ADMUX |= _BV(0);
You could also define this type:
typedef union
byte allBits;
struct {
byte bitZero:1 ;
byte bitOne:1 ;
byte bitTwo:1 ;
byte bitThree:1;
byte bitFour:1;
byte bitFive:1;
byte bitSix:1;
byte bitSeven:1;
} BitField;
//Allowing you to do this:
admux->allBits = 0; //set all bits to 0.
