I tried to find information maximum SD card sizes but had no luck, however, it seems that some people are using 8GB cards. I have 8GB SDHC card (fat32) that I'm trying to use with a Uno Ethernet and not having any luck.
Here is the code:
SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module
created 28 Mar 2011
by Limor Fried
// include the SD library:
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
const int chipSelect = 4;
Serial.print("\nInitializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT); // change this to 53 on a mega
digitalWrite(10, HIGH);
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card is inserted?");
Serial.println("* Is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
return;
Serial.println("Wiring is correct and a card is present.");
// print the type of card
Serial.print("\nCard type: ");
switch(card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
default:
Serial.println("Unknown");
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
if (!volume.init(card)) {
Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
return;
// print the type and size of the first FAT-type volume
long volumesize;
Serial.print("\nVolume type is FAT");
Serial.println(volume.fatType(), DEC);
volumesize = volume.blocksPerCluster(); // clusters are collections of blocks
volumesize *= volume.clusterCount(); // we'll have a lot of clusters
volumesize *= 512; // SD card blocks are always 512 bytes
Serial.print("Volume size (bytes): ");
Serial.println(volumesize);
Serial.print("Volume size (Kbytes): ");
volumesize /= 1024;
Serial.print("Volume size (Mbytes): ");
volumesize /= 1024;
Serial.println("\nFiles found on the card (name, date and size in bytes): ");
root.openRoot(volume);
// list all files in the card with date and size
root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
I get this error on the serial monitor while trying to run the sketch,
Card type: SDHC
I had issues with this card on my android phone, the phone would not recognize or mount the card. Darn thing works in everything else. Is this card just funky?
Thanks, I'll try the formatting tip. The lib is the standard SD lib. I tired to do a SD info run using both the SDfat lib and his code. No dice, the card did not yield any information besides the first few lines which were manufacturer and the like (no real useful info). I'll try the formatting and then the info progie again... Maybe I get luck.
Thanks for the tip on the format sketch!!!!!!!!!! Not only did it get that 8gb card readable, but now it works in my phone also. Is there nothing the arduino cant do.
RobDrizzle:
Card type: SDHC
For the record its a Centon 8gb sdhc class 6. Here is the code:
SD card test
The circuit:
created 28 Mar 2011
by Limor Fried
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
return;
default:
return;
long volumesize;
volumesize /= 1024;
volumesize /= 1024;
void loop(void) {
have a try on the arduino card info example. just change these command. i think it should gonna works. because i've experienced the same problem of yours before. now, no more.
const int chipSelect = 10;
Hi
Thanks cyclegadget for pointing to the SDFAT library.
Just for those with same issue and googling in here, now the library is at V2 and is available from github at this link: https://github.com/greiman/SdFat
This has worked at first shot for me, using a SanDisk 8GB SDHC.
The formatting hint is important! If the SD card is formatted by windows utility, the card is found but seen as not formatted.
