8x16 too bright
After getting my Humidity/Temperature with an 8x16 MAX7219 working with your help the display is too bright. I've tried searching through this group trying to find how to change Intensity. I think it needs to be set from 0-15. Any ideas on the command I need. Thank You.
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 2
#define CLK_PIN   13
#define DATA_PIN  11
#define CS_PIN    10
// Hardware SPI connection
MD_Parola P = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
MD_MAX72XX mx = MD_MAX72XX(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
#include <DHT.h>
#include <DHT_U.h>
#define DHTPIN A0     // Digital pin connected to the DHT sensor
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
DHT dht(DHTPIN, DHTTYPE);
const int buttonPin = 4;
int buttonState = 0;
pinMode(buttonPin, INPUT);
  P.begin();
  dht.begin();
  buttonState = digitalRead(buttonPin);
  // Wait a few seconds between measurements.
  delay(2000);
  float h = dht.readHumidity();
  float f = dht.readTemperature(true);
  f = f - 1;
  if (buttonState == HIGH)
   P.setTextAlignment(PA_CENTER);
   P.print(h,0);
  }else {
   P.print(f,0);
See the documentation for MD_MAX72xx.h - specifically the control() function - I think it's something like mx.control(INTENSITY,number representing the intensity).
you need to add this line after you initialize the matrix
mx.control(INTENSITY, value);
and replace 'value' with whatever value you need.
Use
void setIntensity (uint8_t intensity)
or
void setIntensity (uint8_t z, uint8_t intensity)
The first is global, the second is for one zone.
You should look at the documentation that is in your docs subfolder of the library install.
I looked in the doc folder once and did not understand anything. This time I looked I figured some of it was HTML. Clicked on index and there it all was. Under MD_Parola was P.setIntensity(5); and I put it right below P.begin(); . All is well and not too bright.
