8x64 LED Martix MAX7119 and ESP-01
Hello Marco and all Others.)))
Can I try ESP-01 with MAX7119?
It has 4 GPIO pins: 0, 1(TX), 2 and 3(RX) and none of them CS CLK MOSI pins!
So I could not use SPI.h and MD_MAX72XX(CS_PIN, MAX_DEVICES) function.
And will use MD_MAX72XX(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES) function.
Will it work like this?
What to do to continue using SPI.h?
If I would use SPI.h, Adafruit_GFX.h and Max72xxPanel.h, can i set DATA_PIN, CLK_PIN, CS_PIN "around" SPI.h?
Max72xxPanel.h does not have function like MD_MAX72XX(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES)
Thank you
You will need to use the class initialiser with the arbitrary pins (ie, not using SPI.h).
Yes this is the right approach. It will be slower than the hardware SPI but should work.
Can’t give advice about the other libraries.
Why limit yourself to the ESP-01?
marco_c:
Sorry, could not find what it means. "class initialiser with the arbitrary pins" - my knowledge is not so deep yet
Intend just use
Tx = GPIO 1
Rx = GPIO 3
will disconnect/connect while flashing
The md_max72xx initialisation the specifies the pin numbers.
marco_c:
Than you. That is very good (against Max72xxPanel.h) but still busy to make Cyrillic work with md_max72xx. Particularly with scrollText(char *p)/
