8x8 Bicolor LED Matrix with MAX7219
Hello everyone,
I’m following the circuit below to hook up my 8x8 bicolor LED matrix. So far, I am certain that I hooked up the matrix correctly but I’m not sure if I’m using the right resistor.
Right now, the LED will light up and only display the pattern below, if I try to upload any other patterns it will not change. Also the LEDs which are supposed to be red are showing up as orange at the moment. I’m using a 10uF and .1uF capacitor. I’m currently using a 33k ohm resistor to connect pin 18 to 5V power. (this a guess since I don’t know the forward voltage or amplitude of the matrix. I’m using an LED matrix from this site: https://www.creatroninc.com/product/8x8-led-matrix-20mm/).
Any assistance would be much appreciated!
The MAX7219 can not drive a bi-colour matrix there are not enough outputs to do that.
That means the red and green LEDs are both being lit up.
Have you got a data sheet for the matrix as the pin numbers don't mean much without one.
Ok that is my oversight. I was hoping that a bicolor would still work with the max7219. Unfortunately I can't find the datasheet for it, most bicolor matrices only have 2 rows of pins on either sides. This one has 2 rows on one side and 1 on the other. I will ask for the datasheet and post it here once I have it.
Thanks for the reply!
