8x8 LED display stranger things...
Hi everyone, im trying to simply plug a LED display 8x8 but my display screen doesn't display my byte array.
i've tried to use a basic digitalWrite but my screen doesn't display my datas correctly... then i've tried tu use LedControl library but i've the same render.
i've plugged the screen like this : VCC -> 5v GND -> GND... CLK -> pin 10 MOSI -> pin 12 ( i think MOSI is lie dataIn ) CE -> pin 8
as you can see on the attachment with two different cards i've got the same effect when i try to draw this byte array :
byte icks[8] = { B00000000, B00000000, B00000000, B00000000, B00000000, B00000000, B00000000, B00000001};
Perhaps my display screen is not correctly plugged... Or perhaps the display doesn't work...
this is the display led 8x8 matrix model i've ordered : https://www.amazon.ca/ILS-Matrix-Screen-Arduino-Raspberry/dp/B07911X4Z4
What am doing wrong ? this my second experience with Arduino and its never work so i can't explain the why... is it possible that the new ordered material is disrespectful?
Please tell me what you think because I do not see why the material I ordered would not work ...
There are no attachments.
How did you know what to do to drive the display?
