Hello,
i am completely new to all of this.
I have a lot of teensy, esp8266 and arduino boards at home but never really played with them that much just turned 1 LED on and off and that was basically it.
I was in some local store and i got 8x8 LED matrix for free and wanted to play around with it. I made it work, but process was tedious and i am sure there are better ways of achieving the same...
I put LED matrix in breadboard and connected all 16 pins to teensy then wrote the code to display my name letter by letter. Basically i wrote one loop for every letter and then run every loop a 100 times before going to the next loop or letter.
Do you have any suggestion to tackle this problem with different method to "expand my horizon" ? ![]()
Thank you
Here is displayed part of my code just for quick preview and i attached .ino file with full code
int column1 = 1;
int column2 = 2;
int column3 = 3;
int column4 = 4;
int column5 = 5;
int column6 = 6;
int column7 = 7;
int column8 = 8;
int row1 = 10;
int row2 = 11;
int row3 = 12;
int row4 = 13;
int row5 = 14;
int row6 = 15;
int row7 = 16;
int row8 = 17;
pinMode(column1, OUTPUT);
pinMode(column2, OUTPUT);
pinMode(column3, OUTPUT);
pinMode(column4, OUTPUT);
pinMode(column5, OUTPUT);
pinMode(column6, OUTPUT);
pinMode(column7, OUTPUT);
pinMode(column8, OUTPUT);
pinMode(row1, OUTPUT);
pinMode(row2, OUTPUT);
pinMode(row3, OUTPUT);
pinMode(row4, OUTPUT);
pinMode(row5, OUTPUT);
pinMode(row6, OUTPUT);
pinMode(row7, OUTPUT);
pinMode(row8, OUTPUT);
void loopG(void) {
int var = 0;
while(var < 100){
* TurnOFFALL
digitalWrite(row1, LOW);
digitalWrite(row2, LOW);
digitalWrite(row3, LOW);
digitalWrite(row4, LOW);
digitalWrite(row5, LOW);
digitalWrite(row6, LOW);
digitalWrite(row7, LOW);
digitalWrite(row8, LOW);
digitalWrite(column1, HIGH);
digitalWrite(column2, HIGH);
digitalWrite(column3, HIGH);
digitalWrite(column4, HIGH);
digitalWrite(column5, HIGH);
digitalWrite(column6, HIGH);
digitalWrite(column7, HIGH);
digitalWrite(column8, HIGH);
* Letter G
digitalWrite(column3, LOW);
digitalWrite(column4, LOW);
digitalWrite(column5, LOW);
digitalWrite(column6, LOW);
digitalWrite(row1, HIGH);
delay(1);
delay(1);
digitalWrite(column2, LOW);
digitalWrite(column7, LOW);
digitalWrite(row2, HIGH);
delay(1);
delay(1);
digitalWrite(row3, HIGH);
delay(1);
delay(1);
digitalWrite(row4, HIGH);
delay(1);
delay(1);
digitalWrite(row5, HIGH);
delay(1);
delay(1);
digitalWrite(row6, HIGH);
delay(1);
delay(1);
digitalWrite(row7, HIGH);
delay(1);
delay(1);
digitalWrite(row8, HIGH);
delay(1);
delay(1);
var++;
void loop(void) {
loopG();
loopR();
loopE();
loopG();
loopO();
loopR();
loopDelay();
loopS();
loopA();
loopL();
loopA();
loopM();
loopU();
loopN();
loopDelay();
Teendy20__LEDMatrix16pinNameDisplay.ino (32.1 KB)
