8x8 LED matrix coding problem
I am trying to simply make a "cursor" LED on a 8x8 matrix move around without leaving a trail of LED's behind it.
Hardware:
  1. 1 2-axis joystick(parallax)
  2. 1 8x8 LED matrix (MAX72)
Library:
LedControl-MAX7219-MAX7221
Code:
#include "LedControl.h"
LedControl lc=LedControl(12,11,10,1);
unsigned long delaytime=200;
const int hPin = A0;
const int vPin = A1;
int hVal;
int vVal;
int xPos;
int yPos;
  lc.shutdown(0,false);
  lc.setIntensity(0,8);
  lc.setLed(0,0,0,1);
  delay(delaytime);
  lc.clearDisplay(0);
  pinMode(hPin,INPUT);
  pinMode(vPin,INPUT);
  Serial.println("[setup]");
  xPos = 0;
  yPos = 0;
  hVal = analogRead(hPin);
  vVal = analogRead(vPin);
  Serial.print("Horizontal: ");
  Serial.print(hVal);
  Serial.print("  Vertical: ");
  Serial.println(vVal);
  if(hVal >= 768){
    if(hVal >= 1000){
      xPos = xPos + 256;
    else {xPos = xPos + 128;
  else if(hVal <= 256){
    if(hVal <=24){
      xPos = xPos - 256;
    else {xPos = xPos - 128;
  else{
  Serial.print(" X: ");
  Serial.print(xPos);
  Serial.print(" ");
  if(vVal >= 768){
    if(vVal >= 1000){
      yPos = yPos + 256;
    else {yPos = yPos + 128;
  else if(vVal <= 256){
    if(vVal <=24){
      yPos = yPos - 256;
    else {yPos = yPos - 128;
  else{
  Serial.print(" Y: ");
  Serial.print(yPos);
  Serial.print(" ");
  if(xPos >=1024){
    xPos = 0;
  if(yPos >=1024) {
    yPos = 0;
  if(xPos <0){
    xPos = 1024;
  if(yPos <0) {
    yPos = 1024;
// convert the 0-1024 value of xPos to 0-8 to fit the matrix command
  int xMax;
/*  if(xPos <= 128){
    xMax = 0;
  else if(128 < xPos <= 256){
    xMax = 1;
  else if(256 < xPos <= 384){
    xMax = 2;
  else if(384 < xPos <= 512){
    xMax = 3;
  else if(512 < xPos <= 640){
    xMax = 4;
  else if(640 < xPos <= 768){
    xMax = 5;
  else if(768 < xPos <= 896){
    xMax = 6;
  else if(896 < xPos <= 1024){
    xMax = 7;
xMax = xPos/128;
// convert the 0-1024 value of yPos to 0-8 to fit the matrix command
  int yMax;
/*  if(yPos <= 128){
    yMax = 0;
  if(128 < yPos <= 256){
    yMax = 1;
  if(256 < yPos <= 384){
    yMax = 2;
  if(384 < yPos <= 512){
    yMax = 3;
  if(512 < yPos <= 640){
    yMax = 4;
  if(640 < yPos <= 768){
    yMax = 5;
  if(768 < yPos <= 896){
    yMax = 6;
  if(896 < yPos <= 1024){
    yMax = 7;
yMax = yPos/128;
  Serial.print(" xMax: ");
  Serial.print(xMax);
  Serial.print(" yMax: ");
  Serial.print(yMax);
  lc.setLed(0,xMax,yMax,1);
  int xLast;
  int yLast;
  if(xMax != xLast){
    lc.setLed(0,xLast,yLast,0);
  if(yMax != yLast){
  xLast = xMax;
  yLast = yMax;
My Main problem is "deleting" the dot before the the current one so that there is no trail to the cursor. I tried this with xLast and yLast at the end of the loop but I could not make it work.
Please help!
comment your code, I can't seem to find where you are setting your leds.
but, you need to turn off the current led before proceeding to the next led
void LedControl::setLed(int addr, int row, int column, bool state) {
edit:
at this line:
Change it to:
static int oldxMax = 0;
static int oldyMax = 0;
if(oldxMax != xMax && oldyMax != yMax){
lc.setLed(0,oldxMax,oldyMax,0);
xMax = oldxMax;
yMax = oldyMax;
I just say this code:
  int xLast;
  int yLast;
  if(xMax != xLast){
  if(yMax != yLast){
  xLast = xMax;
  yLast = yMax;
the reason it's not working, is that the variable yLast and xLast are getting destroyed after the function ends, the }, then created again once the function runs again, but they are always zero.
to make them not zero, they need to be global variables, or be static, like I did in my code...
Thank you! I will try this as soon as I can and report back to this topic.
I took your suggestion and slightly modified it and it works!
This is my finished code (this time thoroughly annotated):
//Arduino Uno 8x8 LED matrix "cursor" w/ joystick
// Variables:
const int hPin = A0;   // left/right joystick pin
const int vPin = A1;   // up/down joystick pin
int hVal;              // left/right joystick reading
int vVal;              // up/down joystick reading
int xPos;              // x-axis position
int yPos;              // y-axis position
int xMax;              // matrix column value
int yMax;              // matrix row value
int xLast;             // xMax from last loop
int yLast;             // yMax from last loop
  lc.setLed(0,0,0,1);        // debug led for start of setup
  delay(delaytime);
  lc.clearDisplay(0);
  pinMode(vPin,INPUT);       // set joystick pins as inputs
  Serial.begin(9600);        // start serial communication
  Serial.println("[setup]"); // serial debug for setup
  xPos = 0;                  //
  yPos = 0;                  // "cursor" starting point
  vVal = analogRead(vPin);       // read joytick position pins
  Serial.print("Horizontal: ");  //
  Serial.print(hVal);            //
  Serial.print("  Vertical: ");  //
  Serial.println(vVal);          // serial debug raw joystick data
  if(hVal >= 768){               //
    xPos = xPos + 128;           //
  else if(hVal <= 256){          //
    xPos = xPos - 128;           //
  else{                          // Set sensitivity of when joystick triggers a position change,
  }                              // and the speed at whitch it changes (for x-axis).
  Serial.print(" X: ");          //
  Serial.print(xPos);            //
  Serial.print(" ");             // serial debug x-axis position
  if(vVal >= 768){               //
    yPos = yPos + 128;           //
  else if(vVal <= 256){          //
    yPos = yPos - 128;           //
  }                              // and the speed at whitch it changes (for y-axis).
  Serial.print(" Y: ");          //
  Serial.print(yPos);            //
  Serial.print(" ");             // serial debug y-axis position
  if(xPos >=1024){               //
    xPos = 0;                    //
  }                              // repeat x-axis in positive direction
  if(yPos >=1024) {              //
    yPos = 0;                    //
  }                              // repeat y-axis in positive direction
  if(xPos <0){                   //
    xPos = 1024;                 //
  }                              // repeat x-axis in negative direction
  if(yPos <0) {                  //
    yPos = 1024;                 //
  }                              // repeat y-axis in negative direction
// ! Taken out because of an updated approach (at bottom of this section) !
// convert the 0-1023 value of xPos to 0-7 to fit the matrix command
/*  if(xPos <= 128){
    xMax = 0;
    xMax = 1;
    xMax = 2;
    xMax = 3;
    xMax = 4;
    xMax = 5;
    xMax = 6;
    xMax = 7;
  xMax = xPos/128;               // convert the 1024 value to 0-7 for matrix ( done here instead of when adding value to xPos because it would of went too fast
// convert the 0-1023 value of yPos to 0-7 to fit the matrix command
/*  if(yPos <= 128){
    yMax = 0;
    yMax = 1;
    yMax = 2;
    yMax = 3;
    yMax = 4;
    yMax = 5;
    yMax = 6;
    yMax = 7;
  yMax = yPos/128;               // convert the 1024 value to 0-7 for matrix ( done here instead of when adding value to xPos because it would of went too fast
  Serial.print(" xMax: ");              //
  Serial.print(xMax);                   //
  Serial.print(" yMax: ");              //
  Serial.print(yMax);                   // debug cursor position on matrix
  lc.setLed(0,xMax,yMax,1);             // set cursor position led HIGH (adress,x,y,boolean)
  if(xLast != xMax || yLast != yMax){   //
      lc.setLed(0,xLast,yLast,0);       //
  }                                     // if the last x or y coordinate changed then turn off previous led
  xLast = xMax;                         //
  yLast = yMax;                         // set coordinates for previous led
