8x8 Led matrix turn signal control by switches
I having a problem with my right and left signal.
I connect the 8x8 LED matrix to 2 shift register.
I desire to create a code with (left switch on) left signal on for 1 second then off for 1 second and keep repeat. This goes same to right switch.
This is my code. The output of this code is when left switch on the left signal blinking very fast. The blinking rate as i desire is 1 sec for on and off.
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
int inputPin2 = 2;            // input pin for left (switch)
int inputPin3 = 3;            //input pin for right (switch)
int valleft = 0;
int valright =0;
int LEDs[8][8] = {
  {0, 0, 0, 0, 0, 0, 0, 0},      //blank
int right[8][8] = {
  {0, 0, 0, 0, 1, 0, 0, 0},      //right signal
  {0, 0, 0, 0, 1, 1, 0, 0},
  {1, 1, 1, 1, 1, 1, 1, 0},
  {1, 1, 1, 1, 1, 1, 1, 1},
int left[8][8] = {
  {0, 0, 0, 1, 0, 0, 0, 0},        //left signal
  {0, 0, 1, 1, 0, 0, 0, 0},
  {0, 1, 1, 1, 1, 1, 1, 1},
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(inputPin2, INPUT);
  pinMode(inputPin3, INPUT);
valleft = digitalRead (inputPin2);
valright = digitalRead (inputPin3);
  if (valleft == HIGH) {      //when the left switch is on
lightLED(left);                    //display left signal
delay(1000);                      //waits for 1 sec ( this code seem like not working)
lightLED(LEDs);                   // off
delay(1000):
  else if (valright == HIGH) {
lightLED(right);
lightLED(LEDs);
delay(1000):
lightLED(LEDs);
void lightLED(int tempLED[8][8]) {          //run the lightLED  bit by bit
  byte columnbitsToSend = 0;
  byte rowbitsToSend = 0;
  int x = 0;
  int y = 0;
  for (x = 0; x < 8; x++) {
    rowbitsToSend = 0;
    for (y = 0; y < 8; y ++) {
      if (tempLED[x][y] == 1) {
        bitWrite(rowbitsToSend, y, HIGH);
    digitalWrite(latchPin, LOW);
    bitWrite(columnbitsToSend, x, HIGH);
    shiftOut(dataPin, clockPin, MSBFIRST, columnbitsToSend);
    shiftOut(dataPin, clockPin, MSBFIRST, rowbitsToSend);
    digitalWrite(latchPin, HIGH);
    delay(2);
(code tags added by moderator)
You need to make the delay part of the multiplexing, instead of cyclying thru all the data and then delaying.
Run the multiplexing for longer than just the one pass it gets now.
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
int valleft = 0;
int valright =0;
int LEDs[8][8] = {
    0, 0, 0, 0, 0, 0, 0, 0        }
  ,      //blank
int right[8][8] = {
    0, 0, 0, 0, 1, 0, 0, 0        }
  ,      //right signal
    0, 0, 0, 0, 1, 1, 0, 0        }
    1, 1, 1, 1, 1, 1, 1, 0        }
    1, 1, 1, 1, 1, 1, 1, 1        }
int left[8][8] = {
    0, 0, 0, 1, 0, 0, 0, 0        }
  ,        //left signal
    0, 0, 1, 1, 0, 0, 0, 0        }
    0, 1, 1, 1, 1, 1, 1, 1        }
  int t;
    for (t = 0; t < 64) lightLED(left);  //display left signal
    delay(1000):
    for (t = 0; t < 64) lightLED(right);
    lightLED(LEDs);
    delay(1000):
    lightLED(LEDs);
  int x;
  int y;
    rowbitsToSend = 0;
    delay(2);
Paul__B:
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
int valleft = 0;
int valright =0;
int LEDs[8][8] = {
  ,      //blank
int right[8][8] = {
  ,      //right signal
int left[8][8] = {
  ,        //left signal
  int t;
    delay(1000):
    lightLED(LEDs);
    delay(1000):
    lightLED(LEDs);
int x;
  int y;
    rowbitsToSend = 0;
    delay(2);
May i know why the delay command work with
lightLED(LEDs);
delay(1000); //it is working
and does not work with
lightLED(right);
delay(1000); //not working
My apologies - I corrected the program flow, but failed to spot the glaring typo! Picked that up on my little netbook reading in bed this morning. :smiley:
This should work now - I think!
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
int valleft = 0;
int valright =0;
int LEDs[8][8] = {
  { 0, 0, 0, 0, 0, 0, 0, 0 } , //blank
int right[8][8] = {
  { 0, 0, 0, 0, 1, 0, 0, 0 } , //right signal
  { 0, 0, 0, 0, 1, 1, 0, 0 } ,
  { 1, 1, 1, 1, 1, 1, 1, 0 } ,
  { 1, 1, 1, 1, 1, 1, 1, 1 } ,
int left[8][8] = {
  { 0, 0, 0, 1, 0, 0, 0, 0 } , //left signal
  { 0, 0, 1, 1, 0, 0, 0, 0 } ,
  { 0, 1, 1, 1, 1, 1, 1, 1 } ,
  int t;
    for (t = 0; t < 64; t++) lightLED(left);  //display left signal
    for (t = 0; t < 64; t++) lightLED(right);
    lightLED(LEDs);
    lightLED(LEDs);
  int x;
  int y;
    rowbitsToSend = 0;
    delay(2);
Didn't notice how badly "Auto Format" had mangled the arrays either!
And a few more bugs - wouldn't compile.
Paul__B:
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
int valleft = 0;
int valright =0;
int LEDs[8][8] = {
int right[8][8] = {
int left[8][8] = {
  int t;
    lightLED(LEDs);
    lightLED(LEDs);
int x;
  int y;
    rowbitsToSend = 0;
    delay(2);
Didn't notice how badly "Auto Format" had *mangled* the arrays either!
And a few *more* bugs - wouldn't compile.
Yup. It is working. :slight_smile:
Thanks a lot. ^^
