Paul__B:
My apologies - I corrected the program flow, but failed to spot the glaring typo! Picked that up on my little netbook reading in bed this morning.This should work now - I think!
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
int inputPin2 = 2; // input pin for left (switch)
int inputPin3 = 3; //input pin for right (switch)
int valleft = 0;
int valright =0;
int LEDs[8][8] = {
{ 0, 0, 0, 0, 0, 0, 0, 0 } , //blank
int right[8][8] = {
{ 0, 0, 0, 0, 1, 0, 0, 0 } , //right signal
{ 0, 0, 0, 0, 1, 1, 0, 0 } ,
{ 1, 1, 1, 1, 1, 1, 1, 0 } ,
{ 1, 1, 1, 1, 1, 1, 1, 1 } ,
int left[8][8] = {
{ 0, 0, 0, 1, 0, 0, 0, 0 } , //left signal
{ 0, 0, 1, 1, 0, 0, 0, 0 } ,
{ 0, 1, 1, 1, 1, 1, 1, 1 } ,
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(inputPin2, INPUT);
pinMode(inputPin3, INPUT);
int t;
valleft = digitalRead (inputPin2);
valright = digitalRead (inputPin3);
if (valleft == HIGH) { //when the left switch is on
for (t = 0; t < 64; t++) lightLED(left); //display left signal
lightLED(LEDs); // off
else if (valright == HIGH) {
for (t = 0; t < 64; t++) lightLED(right);
lightLED(LEDs);
lightLED(LEDs);
void lightLED(int tempLED[8][8]) { //run the lightLED bit by bit
byte columnbitsToSend = 0;
byte rowbitsToSend = 0;
int x;
int y;
for (x = 0; x < 8; x++) {
rowbitsToSend = 0;
for (y = 0; y < 8; y ++) {
if (tempLED[x][y] == 1) {
bitWrite(rowbitsToSend, y, HIGH);
digitalWrite(latchPin, LOW);
bitWrite(columnbitsToSend, x, HIGH);
shiftOut(dataPin, clockPin, MSBFIRST, columnbitsToSend);
shiftOut(dataPin, clockPin, MSBFIRST, rowbitsToSend);
digitalWrite(latchPin, HIGH);
delay(2);
Didn't notice how badly "Auto Format" had *mangled* the arrays either! --- And a few *more* bugs - wouldn't compile.
Yup. It is working. ![]()
Thanks a lot. ^^
