8x8 LED Scrolling Display Code Help
Hi
I have the following working code which display HI. Can any one help me out to make a program which display ‘‘This is my String’’. code should be able to get the individual ascii code and map to the look up data. I have attached the schematic. Please help.
Regards
Gk
LED Matrix - Display scrolling text
Version: 1.0
Author: electricteardown (http://insidegadgets.wordpress.com)
Created: 6/11/2010
Last Modified: 6/11/2010
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
//Pin connected to DS of 74HC595
int dataPin = 11;
int counter = 0;
int movement = 0;
int LEDs[8][17] = {
 {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
int letterH[8][8] = {
 {1, 1, 0, 0, 0, 1, 1, 0},
 {1, 1, 1, 1, 1, 1, 1, 0},
int letterI[8][8] = {
 {0, 0, 0, 1, 1, 0, 0, 0},
 //set pins to output because they are addressed in the main loop
 pinMode(latchPin, OUTPUT);
 pinMode(clockPin, OUTPUT);
 pinMode(dataPin, OUTPUT);
 if (movement == 0) {
   int x;
   int y;
   for (x = 0; x < 8; x++) {
     for (y = 0; y < 8; y++) {
       LEDs[x][y+8] = letterH[x][y];
 if (movement == 8) {
   int x;
   int y;
       LEDs[x][y+8] = letterI[x][y];
 if (counter % 25 == 0) {
   movement++;
   int x;
   int y;
     for (y = 0; y < 16; y++) {
       LEDs[x][y] = LEDs[x][y+1];
 if (movement >= 16) {
   counter = 0;
   movement = 0;
 lightLED();
 counter++;
void lightLED() {
 byte columnbitsToSend = 0;
 byte rowbitsToSend = 0;
 int x = 0;
 int y = 0;
   rowbitsToSend = 0;
   for (y = 0; y < 8; y ++) {
     if (LEDs[x][y] == 1) {
       bitWrite(rowbitsToSend, y, HIGH);
   digitalWrite(latchPin, LOW);
   bitWrite(columnbitsToSend, x, HIGH);
   shiftOut(dataPin, clockPin, LSBFIRST, columnbitsToSend);
   shiftOut(dataPin, clockPin, MSBFIRST, rowbitsToSend);
   digitalWrite(latchPin, HIGH);
   delay(2);
(tags added by moderator)
8x8.pdf (19.1 KB)
You should put your code in code tags.
Firstly you will need to define the bit pattern for the letters that you have in your message, because this code only has the letters H and I. If you want all ASCII characters that will take a while.
The encoding is very wasteful and you will run out of memory quickly unless you compress the data. An int is used to represent a 0 or 1. You can use just one bit and drop the requirements per letter from 8x8 = 64 ints = 128 bytes to just 64 bits, which can be packed into 8 bytes.
For the rest, once you have inserted code tags we will be able to read the software.
can you help how to insert code tag?
Gouthamkn:
http://forum.arduino.cc/index.php/topic,148850.0.html
