Hello,
I have tried to setup simple learning project, using 8x8 LED matrix and two 74HC595 shift registers.
I have followed register's wiring in this tutorial: http://arduino.cc/en/tutorial/ShiftOut
But when I have tested it, I couldn't get clear image on display, all leds were flickering during re-drawing procedure, making image nearly unusable. Then I have discovered that if I break +5V connection from adriono to registers, flickering stops and display is working exacly as expected.
I know that I have not used capacitator on latch (because I didn't have one), but I am now really confused that only disconnecting power from my setup solves everything, if there is anyone so kind to explain me what really happened and how to avoid thore mistakes/problems in the future, it would be awesome
AfBU:
Hello,
Unfortunately you seem to be learning lots of bad habits.
As Crossroads said, you should have a 0.1uF bypass cap on each chip. You should also be using series resistors (x 8 ), otherwise you will damage the shift registers or the leds. You should also respect the current limits of the individual outputs and the chip as a whole.
74hc595 is not a great chip for driving leds, it was not designed for that and is current limits are to low to drive a matrix properly without damage. Max7219 is a much better chip for this.
