8x8 Matrix - yes, another one
I received a test 8x8 RGB matrix, common anode. For common cathode, Maxim has the MAX7219 which is a serial 8-Digit driver which would work beautifully. 8 segments, 8 digits = 64 LEDs. Use three of them, one per color. Voila.
However, for common anode, they don't seem to have a serial driver. They have 8-digit drivers, but not serial. They have something called 'microprocessor compatible' (ICM7218) but it's not the same. So does anyone have a suggestion of an IC that's comparable to their MAX7219, but for common anode?
I suppose I can always tell the manufacturer to send me a different f-ing matrix. :)
Anyone? Bueller? Bueller? Bueller?
http://www.rocketnumbernine.com/2010/11/11/using-the-icm7218icm7228-led-driver offers some insight to your problem.
You could look into the ICM7218 or ICM7228, they are similar to the 7219 and are for common anode parts. http://datasheets.maxim-ic.com/en/ds/ICM7218-ICM7228.pdf
I'm pretty sure Maxim also has an application note for adding external transistors to allow MAX7219 to drive common anode vs common cathode, but I can't find it at the moment.
