8x8 RGB LED matrix with 74hc595 shift out
Hello to all experts in Arduino,
has become a new member of the Arduino world and trying to teach me how to Arduino works.
Have done various exercises and it becomes more and more enjoyable for every project.
Now I've got rgb led matrix (8x8) and would like to pair this with my Arduino according to the following schedule:
data sheet for the led matrix are:
I have tried to copy the code that exists here on the forum but nothing works. I really want to learn how to control a diode in any row or column in order to later decide how it should look like.
grateful if someone can help me.
Schedule:
http://picasaweb.google.com/lh/photo/4m0f5w6KA1bAIHIswXBFcg?feat=directlink
http://www.swechtrading.se/zencart/images/sw8x8rgb.pdf
OK, now I understand how this mechanism works, finally.
Now is the question of where can I find libraries for characters and how to get this to scroll.
Here is code:
#define __spi_clock 13   // SCK - hardware SPI
#define __spi_latch 10
#define __spi_data 11    // MOSI - hardware SPI
#define __spi_data_in 12 // MISO - hardware SPI (unused)
#define __display_enable 9
#define __rows 8
#define __max_row __rows-1
#define __leds_per_row 8
#define __max_led __leds_per_row-1
#define __brightness_levels 16 // 0...15 above 28 is bad for ISR ( move to timer1, lower irq freq ! )
#define __max_brightness __brightness_levels-1
#define __fade_delay 8
#define INIT_TIMER_COUNT 0
#define RESET_TIMER2 TCNT2 = INIT_TIMER_COUNT
#include <avr/interrupt.h>
#include <avr/io.h>
byte brightness_red[__leds_per_row][__rows];
byte brightness_green[__leds_per_row][__rows];
byte brightness_blue[__leds_per_row][__rows];
ISR(TIMER2_OVF_vect) {
 RESET_TIMER2; // precharge TIMER2 to maximize ISR time --> max led brightness
 byte cycle;
 for(cycle = 0; cycle < __max_brightness; cycle++) {
   byte led;
   byte row = B00000000;    // row: current source. on when (1)
   byte red;    // current sinker when on (0)
   byte green;  // current sinker when on (0)
   byte blue;   // current sinker when on (0)
   for(row = 0; row <= __max_row; row++) {
     red = B11111111;    // off
     green = B11111111;  // off
     blue = B11111111;   // off
     for(led = 0; led <= __max_led; led++) {
       if(cycle < brightness_red[row][led]) {
         red &= ~(1<<led);
       if(cycle < brightness_green[row][led]) {
         green &= ~(1<<led);
       if(cycle < brightness_blue[row][led]) {
         blue &= ~(1<<led);
     digitalWrite(__spi_latch,LOW);
     spi_transfer(blue);
     spi_transfer(green);
     spi_transfer(red);
     spi_transfer(B00000001<<row);
     digitalWrite(__spi_latch,HIGH);
 // turn off all leds when ISR is not running
 // otherwise leds will flash to full brightness when 1111 is set, which
 // stays on outside the ISR !
 spi_transfer(B11111111); // blue off
 spi_transfer(B11111111); // green off
 spi_transfer(B11111111); // red off
 spi_transfer(B00000000); // rows off
void setup(void) {
 randomSeed(555);
 byte ctr1;
 byte ctr2;
 pinMode(__spi_clock,OUTPUT);
 pinMode(__spi_latch,OUTPUT);
 pinMode(__spi_data,OUTPUT);
 pinMode(__spi_data_in,INPUT);
 pinMode(__display_enable,OUTPUT);
 digitalWrite(__spi_data,LOW);
 digitalWrite(__spi_clock,LOW);
 byte clr;
 SPCR |= ( (1<<SPE) | (1<<MSTR) ); // enable SPI as master
 //SPCR |= ( (1<<SPR1) | (1<<SPR0) ); // set prescaler bits
 SPCR &= ~( (1<<SPR1) | (1<<SPR0) ); // clear prescaler bits
 clr=SPSR; // clear SPI status reg
 clr=SPDR; // clear SPI data reg
 SPSR |= (1<<SPI2X); // set prescaler bits
 //SPSR &= ~(1<<SPI2X); // clear prescaler bits
 delay(10);
 set_matrix_rgb(0,0,0);
 digitalWrite(__display_enable,LOW);
 // set irq to 61 Hz: CS22-bit = 1, CS21-bit = 1, CS20-bit = 1
 TCCR2B |= ( (1<<CS22) | (1<<CS21) | (1<<CS20));
 // Use normal mode
 TCCR2A &= ~( (1<<WGM21) | (1<<WGM20) );
 TCCR2B &= ~( (1<<WGM22) );
 //Timer2 Overflow Interrupt Enable
 TIMSK2 |= (1<<TOIE2);
 TIMSK2 &= ~( (1<<OCIE2A) | (1<<OCIE2B) );
 RESET_TIMER2;
 // enable all interrupts
 sei();
void loop(void) {
 int ctr;
 for(ctr=0; ctr < 4; ctr++) {
   matrix_heart_2();
 smile_blink(200,8,100);
 delay(2500);
 explode(300,500);
byte spi_transfer(byte data)
 SPDR = data;                    // Start the transmission
 while (!(SPSR & (1<<SPIF)))     // Wait the end of the transmission
 return SPDR;                    // return the received byte, we don't need that
void set_led_red(byte row, byte led, byte red) {
 brightness_red[row][led] = red;
void set_led_green(byte row, byte led, byte green) {
 brightness_green[row][led] = green;
void set_led_blue(byte row, byte led, byte blue) {
 brightness_blue[row][led] = blue;
void set_led_rgb(byte row, byte led, byte red, byte green, byte blue) {
 set_led_red(row,led,red);
 set_led_green(row,led,green);
 set_led_blue(row,led,blue);
void set_led_hue(byte row, byte led, int hue) {
 // see wikipeda: HSV
 float S=100.0,V=100.0,s=S/100.0,v=V/100.0,h_i,f,p,q,t,R,G,B;
   hue = hue%360;
   h_i = hue/60;
   f = (float)(hue)/60.0 - h_i;
   p = v*(1-s);
   q = v*(1-s*f);
   t = v*(1-s*(1-f));
   if      ( h_i == 0 ) {
     R = v;
     G = t;
     B = p;
   else if ( h_i == 1 ) {
     R = q;
     G = v;
     B = p;
   else if ( h_i == 2 ) {
     R = p;
     G = v;
     B = t;
   else if ( h_i == 3 ) {
     R = p;
     G = q;
     B = v;
   else if ( h_i == 4 ) {
     R = t;
     G = p;
     B = v;
   else                   {
     R = v;
     G = p;
     B = q;
   set_led_rgb(row,led,byte(R*(float)(__max_brightness)),byte(G*(float)(__max_brig
htness)),byte(B*(float)(__max_brightness)));
void set_matrix_rgb(byte red, byte green, byte blue) {
 byte ctr1;
 byte ctr2;
 for(ctr2 = 0; ctr2 <= __max_row; ctr2++) {
   for(ctr1 = 0; ctr1 <= __max_led; ctr1++) {
     set_led_rgb(ctr2,ctr1,red,green,blue);
void set_matrix_hue(int hue) {
 byte ctr1;
 byte ctr2;
     set_led_hue(ctr2,ctr1,hue);
void set_row_rgb(byte row, byte red, byte green, byte blue) {
 byte ctr1;
     set_led_rgb(row,ctr1,red,green,blue);
void set_column_rgb(byte column, byte red, byte green, byte blue) {
 byte ctr1;
 for(ctr1 = 0; ctr1 <= __max_row; ctr1++) {
     set_led_rgb(ctr1,column,red,green,blue);
void set_row_hue(byte row, int hue) {
 byte ctr1;
     set_led_hue(row,ctr1,hue);
void set_column_hue(byte column, int hue) {
 byte ctr1;
     set_led_hue(ctr1,column,hue);
void set_row_byte_hue(byte row, byte data_byte, int hue) {
 byte led;
   if( (data_byte>>led)&(B00000001) ) {
     set_led_hue(row,led,hue);
   else {
     set_led_rgb(row,led,0,0,0);
void fader(void) {
 byte ctr1;
 byte row;
 byte led;
 for(ctr1 = 0; ctr1 <= __max_brightness; ctr1++) {
       set_led_rgb(row,led,ctr1,ctr1,ctr1);
   delay(__fade_delay);
 for(ctr1 = __max_brightness; (ctr1 >= 0) & (ctr1 != 255); ctr1--) {
void fader_hue(void) {
 int ctr1;
 byte row;
 byte led;
 for(ctr1 = 0; ctr1 < 360; ctr1=ctr1+3) {
   set_matrix_hue((float)(ctr1));
void matrix_heart(int hue) {
 set_row_byte_hue(1,B00110110,hue);
 set_row_byte_hue(2,B01111111,hue);
 set_row_byte_hue(3,B01111111,hue);
 set_row_byte_hue(4,B00111110,hue);
 set_row_byte_hue(5,B00011100,hue);
 set_row_byte_hue(6,B00001000,hue);
void matrix_test(void) {
 byte ctr1;
 byte ctr2;
 int hue;
 for(hue = 0; hue < 360; hue=hue+32) {
       delay(5);
void matrix_heart_2(void) {
 int hue;
 for(hue = 0; hue < 360; hue=hue+16) {
   delay(3*__fade_delay);
void rainbow(void) {
 byte column;
 for(column = 0; column <= __max_led; column++) {
   set_column_hue(column,column*50);
void color_wave(int width) {
 byte column;
 static int shift = 0;
   set_column_hue(column,column*width+shift);
 shift++;
void random_leds(void) {
 set_led_hue((byte)(random(__rows)),(byte)(random(__leds_per_row)),(int)(random(
360)));
void smile_on(int hue) {
 set_row_byte_hue(0,B00000000,hue);
 set_row_byte_hue(1,B01100110,hue);
 set_row_byte_hue(2,B01100110,hue);
 set_row_byte_hue(3,B00000000,hue);
 set_row_byte_hue(4,B00011000,hue);
 set_row_byte_hue(5,B10011001,hue);
 set_row_byte_hue(6,B01000010,hue);
 set_row_byte_hue(7,B00111100,hue);
void smile_off(int hue) {
 set_row_byte_hue(1,B00000000,hue);
void smile_blink(int hue, byte times, int pause) {
byte ctr;
for(ctr = 0; ctr < times; ctr++) {
  delay(pause);
  smile_on(hue);
  delay(pause);
  smile_off(hue);
  delay(pause);
  smile_on(hue);
void explode(int hue, byte pause) {
 set_row_byte_hue(2,B00000000,hue);
 set_row_byte_hue(3,B00011000,hue);
 set_row_byte_hue(5,B00000000,hue);
 set_row_byte_hue(6,B00000000,hue);
 set_row_byte_hue(7,B0000
This piece of code still uses timer2. I suggest moving to timer1, it has the potential to give the interrupt code more time if needed (lower timer overflow frequency possible). That can prevent a lock up. Also have a look at a slightly updated version of the HUE setting code. It now does without all the float stuff. Should be quicker and produce smaller code.
As for the scrolling, have a look around. I think that people at evilmadscientist.com have developed a red scrolling 8x8 matrix. But be warned, they don't use the 'Arduino security blanket'.
Latest incarnations of my matrix code can be found here. The floating-point-math-less HUE code is hidden in there. Once you know the code, you should be able to integrate the latter into the former.
You may need to adjust the sequence of shifting out the data, so it matches the schematic you got from Francis' site. Also your type of RGB matrix is one of those with a totally whacky pinout.
Schedule:
That schematic is a bit odd. It only has the current sourcing capacity of a 74HC595 which is about 20mA, that is spread over all 8 LEDs for all 3 colours, that leaves less than 1mA each if they are all on. Therefore you will not be able to have a very bright display if they are many LEDs on at the same time. I assume you will see something if there are only a few LEDs on but it is a very badly designed schematic because the anode powering chip is badly over stressed.
To make it better you should use the output of this chip to drive some P channel FETs and drive the anodes from that.
Mike in your redesign of this circuit would you only put FETs on the anode chip? How does this work?
I am looking to use this circuit to drive more powerful LEDs. Would I also have to put other transistors before each LED's?
I would be grateful for your input
Matt
Look at the way I have done the driving here:-
http://www.thebox.myzen.co.uk/Hardware/Econo_Monome.html
There is a FET (p-type) in each row being driven by a decoder chip. Pulling down each column is a darlington although it can be a FET if you want.
This should allow you to power bigger LEDs but not the high power type, that require a constant current supply and is a much more complex system.
