8x8 SparkFun LED Matrix
Hello everyone, I did not find the answer I was looking for, but if you happen to know a link would be just fine. I am trying to alter the sample code for the 8x8 Spark Fun LED MATRIX (RGB) to animate it, but I seem to be having trouble. Below is the code that I have and I am not sure what elements need to be changed. Thanks so much for any help.
// Writing to the RGB Serial Backpack Matrix from SparkFun Electronics
// by Ryan Owens
// Copyright SparkFun Electronics
//Define the "Normal" Colors
#define BLACK 0
#define RED 0xE0
#define GREEN 0x1C
#define BLUE 0x03
#define ORANGE RED|GREEN
#define MAGENTA RED|BLUE
#define TEAL BLUE|GREEN
#define WHITE (RED|GREEN|BLUE)-0xA0
//Define the SPI Pin Numbers
#define DATAOUT 11//MOSI
#define DATAIN 12//MISO
#define SPICLOCK 13//sck
#define SLAVESELECT 10//ss
//Define the variables we'll need later in the program
char color_buffer [64];
//SPI Bus setup
SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR1); //Enable SPI HW, Master Mode, divide clock by 16 //SPI Bus setup
//Set the pin modes for the RGB matrix
pinMode(DATAOUT, OUTPUT);
pinMode(DATAIN, INPUT);
pinMode(SPICLOCK,OUTPUT);
pinMode(SLAVESELECT,OUTPUT);
//Make sure the RGB matrix is deactivated
digitalWrite(SLAVESELECT,HIGH);
//Load colors into the first row color buffer array.
//This will be the array of colors sent to the RGB matrix.
color_buffer[10]=MAGENTA;
color_buffer[11]=MAGENTA;
color_buffer[12]=MAGENTA;
color_buffer[13]=MAGENTA;
color_buffer[17]=MAGENTA;
color_buffer[18]=MAGENTA;
color_buffer[19]=MAGENTA;
color_buffer[20]=MAGENTA;
color_buffer[21]=MAGENTA;
color_buffer[22]=MAGENTA;
color_buffer[25]=MAGENTA;
color_buffer[26]=MAGENTA;
color_buffer[27]=MAGENTA;
color_buffer[28]=MAGENTA;
color_buffer[29]=MAGENTA;
color_buffer[30]=MAGENTA;
color_buffer[33]=MAGENTA;
color_buffer[34]=MAGENTA;
color_buffer[35]=MAGENTA;
color_buffer[36]=MAGENTA;
color_buffer[37]=MAGENTA;
color_buffer[38]=MAGENTA;
color_buffer[41]=MAGENTA;
color_buffer[42]=MAGENTA;
color_buffer[43]=MAGENTA;
color_buffer[44]=MAGENTA;
color_buffer[45]=MAGENTA;
color_buffer[46]=MAGENTA;
color_buffer[50]=MAGENTA;
color_buffer[51]=MAGENTA;
color_buffer[52]=MAGENTA;
color_buffer[53]=MAGENTA;
//Activate the RGB Matrix
digitalWrite(SLAVESELECT, LOW);
//Send the color buffer to the RGB Matrix
for(int LED=0; LED<64; LED++){
spi_transfer(color_buffer[LED]);
//Deactivate the RGB matrix.
digitalWrite(SLAVESELECT, HIGH);
while(1);
//delay(100); // allow some time for the Serial data to be sent
//Use this command to send a single color value to the RGB matrix.
//NOTE: You must send 64 color values to the RGB matrix before it displays an image!
char spi_transfer(volatile char data)
SPDR = data; // Start the transmission
while (!(SPSR & (1<<SPIF))) // Wait for the end of the transmission
return SPDR; // return the received byte
It would be a real big help if you told us what kind of trouble. Is your girlfriend pregnant? Was your son kicked out of school? Did your dog run off with the neighbor's cat?
