9 bit serial
Hi, i read the documentation of the atmega328 for 9bit serial, but cant find any hint which bit is send first. Is it the one in the TXB8 or are the other 8 bits send first?
greetings Tarcontar
The diagrams show transmission with the lowest bit (0) first. But why bother with transmission direction, simply follow the sample code for sending and receiving 9 data bits.
since i want to connect to the MDB bus, so i need to know which bit is send first,
the spec is: 1 start, 8 data, 1 mode, 1 end
Then mode should be sent as the 9th bit (TXB8).
ok thx
