9 DOF sensor stick + Open Log trouble
BINGO!! I figured out my problem
first: I was using the wrong logger I was using the ethernet shield SD card slot
not the open log apparently there IS a difference
second: If i'm correct open log finds and reads automatic from any analog port
the rx and tx is used to READ data from the analog ports so I never needed the open log to
read ports A4 A5
Sounds like the device is using I2C to communicate with the Arduino - thus the A4/A5 pins.
looks that way the open log reads from all analog ports any way so I never needed any special code to read the 9dof sensor stick then I just need openlog to record everything to the uSD card which is 16 GB
but if I remember correctly the older versions of the code can only log data at 2 GB which is ok I have one anyway so now my question is is there an openlog sketch out there that logs data as long as the arduino is powered?
BINGO!! I think I got it!
but I need an expert opinion
#include <Wire.h>
#include <SD.h>
char buff[50];
int fileNumber;
int resetOpenLog = 2;
//i2c write
void i2c_write(int address, byte reg, byte data) {
  // Send output register address
  Wire.beginTransmission(address);
  Wire.send(reg);
  // Connect to device and send byte
  Wire.send(data); // low byte
  Wire.endTransmission();
//i2c read
void i2c_read(int address, byte reg, int count, byte* data) {
  int i = 0;
  // Send input register address
  Wire.send(reg);
  // Connect to device and request bytes
  Wire.requestFrom(address,count);
  while(Wire.available()) // slave may send less than requested
    char c = Wire.receive(); // receive a byte as character
    data[i] = c;
    i++;
//Accelerometer
#define  ADXL345_ADDRESS (0xA6 >> 1)
//There are 6 data registers, they are sequential starting
//with the LSB of X.  We'll read all 6 in a burst and won't
//address them individually
#define ADXL345_REGISTER_XLSB (0x32)
//Need to set power control bit to wake up the adxl345
#define ADXL_REGISTER_PWRCTL (0x2D)
#define ADXL_PWRCTL_MEASURE (1 << 3)
void init_adxl345() {
  byte data = 0;
  i2c_write(ADXL345_ADDRESS, ADXL_REGISTER_PWRCTL, ADXL_PWRCTL_MEASURE);
  //Check to see if it worked!
  //  i2c_read(ADXL345_ADDRESS, ADXL_REGISTER_PWRCTL, 1, &data);
  //  Serial.println((unsigned int)data);
int accelerometer_data[3];
void read_adxl345() {
  byte bytes[6];
  memset(bytes,0,6);
  //read 6 bytes from the ADXL345
  i2c_read(ADXL345_ADDRESS, ADXL345_REGISTER_XLSB, 6, bytes);
  //now unpack the bytes
  for (int i=0;i<3;++i) {
    accelerometer_data[i] = (int)bytes[2*i] + (((int)bytes[2*i + 1]) << 8);
//Gyroscope
#define ITG3200_ADDRESS (0xD0 >> 1)
//request burst of 6 bytes from this address
#define ITG3200_REGISTER_XMSB (0x1D)
#define ITG3200_REGISTER_DLPF_FS (0x16)
#define ITG3200_FULLSCALE (0x03 << 3)
#define ITG3200_42HZ (0x03)
void init_itg3200() {
  byte data = 0;
  //Set DLPF to 42 Hz (change it if you want) and
  //set the scale to "Full Scale"
  i2c_write(ITG3200_ADDRESS, ITG3200_REGISTER_DLPF_FS, ITG3200_FULLSCALE | ITG3200_42HZ);
  //  //Sanity check! Make sure the register value is correct.
  //  i2c_read(ITG3200_ADDRESS, ITG3200_REGISTER_DLPF_FS, 1, &data);
int gyro_data[3];
void read_itg3200() {
  byte bytes[6];
  memset(bytes,0,6);
  //read 6 bytes from the ITG3200
  i2c_read(ITG3200_ADDRESS, ITG3200_REGISTER_XMSB, 6, bytes);  //now unpack the bytes
    gyro_data[i] = (int)bytes[2*i + 1] + (((int)bytes[2*i]) << 8);
//Magenetometer
#define HMC5843_ADDRESS (0x3C >> 1)
//First data address of 6 is XMSB.  Also need to set a configuration register for
//continuous measurement
#define HMC5843_REGISTER_XMSB (0x03)
#define HMC5843_REGISTER_MEASMODE (0x02)
#define HMC5843_MEASMODE_CONT (0x00)
void init_hmc5843() {
  byte data = 0;
  //set up continuous measurement
  i2c_write(HMC5843_ADDRESS, HMC5843_REGISTER_MEASMODE, HMC5843_MEASMODE_CONT);
  //Sanity check, make sure the register value is correct.
  //  i2c_read(HMC5843_ADDRESS, HMC5843_REGISTER_MEASMODE, 1, &data);
int magnetometer_data[3];
void read_hmc5843() {
  byte bytes[6];
  memset(bytes,0,6);
  //read 6 bytes from the HMC5843
  i2c_read(HMC5843_ADDRESS, HMC5843_REGISTER_XMSB, 6, bytes);
    magnetometer_data[i] = (int)bytes[2*i + 1] + (((int)bytes[2*i]) << 8);
unsigned long tme = 0;
unsigned long ret = 0;
int length = 6; //not used
// Code Begins
//SDcard
  pinMode(resetOpenLog, OUTPUT);
  randomSeed(analogRead(0));
  Wire.begin();
  //Reset OpenLog
  digitalWrite(resetOpenLog, LOW);
  delay(100);
  digitalWrite(resetOpenLog, HIGH);
  Serial.println("card initialized.");
  //Wait for OpenLog to respond with '<' to indicate it is alive and recording to a file
  while(1) {
    if(Serial.available())
      if(Serial.read() == '<') break;
 fileNumber = random(999); //Select a random file #, 0 to 999
    //Send new (random from 0 to 999) file name
  //Old way
  sprintf(buff, "new LOG%03d.txt\r", fileNumber);
  Serial.print(buff); //\r in string + regular print works with older v2.5 Openlogs
 sprintf(buff, "append LOG%03d.txt\r", fileNumber);
  Serial.print(buff);
  //Wait for OpenLog to indicate file is open and ready for writing
  while(1) {
    //Sensor stick
    init_adxl345();
    init_hmc5843();
    init_itg3200();
//Timer
    //while (millis() <= 20000)   // not in use yet, collects dat, can be changed
    tme = millis();
    if (tme - ret >= 1000){ //results in 1-sec readings
      int secs = tme/1000;
      Serial.print ("secs = ");
      Serial.println (secs);
      ret = tme;
  //SD card
      read_adxl345();
      Serial.print("ACCEL: ");
      Serial.print(accelerometer_data[0]);
      Serial.print("\t");
      Serial.print(accelerometer_data[1]);
      Serial.print("\t");
      Serial.print(accelerometer_data[2]);
      Serial.print("\n");
      read_hmc5843();
      Serial.print("MAG: ");
      Serial.print(magnetometer_data[0]);
      Serial.print(",");
      Serial.print(magnetometer_data[1]);
      Serial.print(",");
      Serial.print(magnetometer_data[2]);
      Serial.print("\n");
      read_itg3200();
      Serial.print("GYRO: ");
      Serial.print(gyro_data[0]);
      Serial.print("\t");
      Serial.print(gyro_data[1]);
      Serial.print("\t");
      Serial.print(gyro_data[2]);
      Serial.print("\n");
      //Sample at 10Hz
      delay(100);
It looks ok but still there is possibility I made a mistake
my hardware is an arduino pro mini 5v sparkfun 9 dof sensor stick and a open log
my goal is simply to log the data from the sensor stick without the serial monitor
while having the setup to record the data
darn not quite I'm getting a not in sync error resp 0=0x00
protocol error, expect=0x14, resp=0x51
something like that I believe there is a simple fix but I cannot remember where
so i'm asking once again for help on the matter
Nevermind it works A ok 8)
For those that are interested here's what I have
#include <Wire.h>
char buff[50];
int fileNumber;
//i2c write
  Wire.send(reg);
//i2c read
  int i = 0;
  Wire.send(reg);
    data[i] = c;
    i++;
//Accelerometer
  byte data = 0;
  byte bytes[6];
  memset(bytes,0,6);
//Gyroscope
  byte data = 0;
int gyro_data[3];
  byte bytes[6];
  memset(bytes,0,6);
//Magenetometer
  byte data = 0;
  byte bytes[6];
  memset(bytes,0,6);
// Code Begins
//SDcard
  Wire.begin();
  //Reset OpenLog
  delay(100);
  while(1) {
  //fileNumber = random(999); //Select a random file #, 0 to 999
  //Old way
  //  sprintf(buff, "new LOG%03d.txt\r", fileNumber);
  //  Serial.print(buff); //\r in string + regular print works with older v2.5 Openlogs
  //New way
  //sprintf(buff, "new LOG%03d.txt", fileNumber);
  //Serial.println(buff); //regular println works with v2.51 and above
  // sprintf(buff, "append LOG%03d.txt\r", fileNumber);
  //Sensor stick
  init_adxl345();
  init_hmc5843();
  init_itg3200();
//Timer
  tme = millis();
    ret = tme;
  //SD card
  // make a string for assembling the data to log:
    read_adxl345();
    Serial.print("\t");
    Serial.print("\t");
    Serial.print("\n");
    read_hmc5843();
    Serial.print(",");
    Serial.print(",");
    Serial.print("\n");
    read_itg3200();
    Serial.print("\t");
    Serial.print("\t");
    Serial.print("\n");
    //Sample should be at 10 per sec
    delay(95);
but keep in mind to use this the arduino must power up "first" once done add the micro sd card
or a reset button must be in place to reset if in enclosed designs
