:99:1: error: expected initializer before 'switch' Error
Hi I get such error compiling, which mean, that there is not closed sentense by ; but I check it and semicolons are everywhere. I already break my my mind why this error compiling can be? Or just my syntax improperly writed?
My actions already made - I remove all ; one by one and change it to new ; - get same error compiling. Then I rewrite code (was IF, and i changed it to Switch Case) - get same error compiling. And the error compiling dissapeared, if I remove new piece of code, in spite of I don't add any semicolons (;) to code.
The piece of code which I must remove to get error free compile, is below. Of coarce it's not full text, but when it commented, all the rest are compile well.
//-----------correction1 of direction movement it will checked each cycle, and void
void corr () // check if pressed some buttonrect moving direction in case vehicle not find obstakle accidentally
           if (incomingByte() = x )  {
                                        st();
            if (incomingByte() = f )
                                      lf();
                                      rf();
  else{ Serial.println(incomingByte);// say what you got:
//-----------end of correction
//-----------correction2 of direction movement it will checked each cycle, and void
switch (incomingByte) {
  case x:
    Serial.println("stop");// say what you got:// say what you got:   // statements
  case f:
    Serial.println("forward");// say what you got:
  default:
I already breack my mind, what is improperly in it syntax?
will be apologise for any Idea. Thanks.
void corr () {
incomingByte() = x
I'm guessing you really want "=="
thanks, it really works now, I was break my mind the second day!
