The BNO055 is very old and the calibration has never worked well.
Unfortunately, to get heading from a magnetometer, calibration is absolutely required. They don't work out of the box, and magnetic fields in the local environment must be taken into account.
Fortunately, for a large robot, calibration in the horizontal plane can work well. Simply rotate the robot through 360 degrees about the vertical axis, and correct the (X, Y raw data) points to lie on a circle centered on the origin.
Matlab/GNU Octave code for 2D calibration:
% File: magcal_2d.m
% This MATLAB program calculates the calibration parameters for a 2D magnetometer.
% As is customary, data for one or two complete revolutions of the magnetometer
% should be collected while held level, points closely spaced if possible.
% S. James Remington 8/2013
% uses published Matlab function EllipseDirectFit.m
% http://www.mathworks.com/matlabcentral/fileexchange/22684-ellipse-fit-direct-method
% First step: collect data and produce a CSV file (comma separated values) of
% magnetometer X and Y values (can be raw). No column headings!
% Second: execute magcal_2d.m
% This work was inspired by the 3D procedure described in:
% http://sailboatinstruments.blogspot.com/2011/08/improved-magnetometer-calibration.html
% no column headings allowed!
Book1 = csvread('mag2d_raw.csv');
A = EllipseDirectFit(Book1);
% modified coefficients of equation for ellipse
% from http://mathworld.wolfram.com/Ellipse.html
a = A(1);
b = A(2)/2;
c = A(3);
d = A(4)/2;
f = A(5)/2;
g = A(6);
% X0, Y0 offset (centroid of ellipse)
x0 = (c*d - b*f)/(b^2 - a*c);
y0 = (a*f - b*d)/(b^2 - a*c);
% semimajor and semiminor axes
numer = 2*(a*f*f+c*d*d+g*b*b-2*b*d*f-a*c*g);
denom1 = (b*b-a*c)*( sqrt((a-c)^2 + 4*b*b) - (a+c));
denom2 = (b*b-a*c)*(-sqrt((a-c)^2 + 4*b*b) - (a+c));
a_axis = sqrt(numer/denom1);
b_axis = sqrt(numer/denom2);
% angle of ellipse semimajor axis wrt X-axis
if (a < c) theta = 0.5*acotd((a-c)/(2*b));
else theta = 90.0 + 0.5*acotd((a-c)/(2*b));
end
s=sprintf('x0 = %5.2f y0 = %5.2f a = %5.2f, b= %5.2f, theta(d) = %4.1f', ...
x0,y0,a_axis,b_axis, theta);
disp(s);
% rotation matrix to align semimajor axis to X-axis
ct=cosd(theta);
st=sind(theta);
R = [ct st; -st ct];
xy0 = [x0 y0];
%rescale vector, correct for difference in magnetometer X & Y gains
scale = [b_axis/a_axis,1];
% final result: matrix to align ellipse axes wrt coordinates system, normalize X and Y gains and rotate back.
Q = R^-1*([scale(1) 0; 0, scale(2)]*R);
% correct the input data
xy = ( Q*(Book1-xy0)' )';
csvwrite('corrected_data.csv',xy);
% replot scaled data
figure;
axis equal;
scatter(Book1(:,1),Book1(:,2));
hold on;
scatter(xy(:,1),xy(:,2))
legend('raw','corrected');
disp(' ');
disp('scaled rotation matrix and vector to apply: Q*(XY-XY0)');
s = sprintf('(%6.4f %6.4f)*(X - (%5.1f))',Q(1,1),Q(1,2),x0);
disp(s);
s = sprintf('(%6.4f %6.4f)*(Y - (%5.1f))',Q(2,1),Q(2,2),y0);
disp(s);
Both the above Matlab/GNU Octave code, as well as a Python implementation are posted on github.
