9Dof Imu Sensor Results
Can someone please check with me whether the values I obtained from the 9Dof Sensor stick
(Accelerometer, Magnetometer and gyroscope) when placed on a table are correct? Thank you.
I am using a Arduino Micro board.
Here's the code for it:
 #include <Adafruit_Sensor.h>
#include <Wire.h>
#define ADXL345_ADDRESS (0XA6 >> 1)
#define ADXL345_REGISTER_XLSB (0x32)
#define ADXL_REGISTER_PWRCTL (0x2D)
#define ADXL_PWRCTL_MEASURE (1 << 3)
#define ITG3200_ADDRESS (0xD0 >> 1)
#define ITG3200_REGISTER_XMSB (0x1D)
#define ITG3200_REGISTER_DLPF_FS (0x16)
#define ITG3200_FULLSCALE (0x03 << 3)
#define ITG3200_42HZ (0x03)
#define HMC5843_ADDRESS (0x3C >> 1)
#define HMC5843_REGISTER_XMSB (0x03)
#define HMC5843_REGISTER_MEASMODE (0x02)
#define HMC5843_MEASMODE_CONT (0x00)
int accelerometer_data[3];
int gyro_data[3];
int magnetometer_data[3];
char c;
  Wire.begin();
  for(int i = 0; i < 3; ++i)
    accelerometer_data[i] = magnetometer_data[i] = gyro_data[i] = 0;
  init_adxl345();
  init_hmc5843();
  init_itg3200();
   read_adxl345();
   Serial.print("ACCEL: ");
   Serial.print(accelerometer_data[0]);
   Serial.print("\t");
   Serial.print(accelerometer_data[1]);
   Serial.print("\t");
   Serial.print(accelerometer_data[2]);
   Serial.print("\t");
   read_hmc5843();
   Serial.print("MAG: ");
   Serial.print(magnetometer_data[0]);
   Serial.print(",");
   Serial.print(magnetometer_data[1]);
   Serial.print(",");
   Serial.print(magnetometer_data[2]);
   Serial.print("\t");
   read_itg3200();
   Serial.print("GYRO: ");
   Serial.print(gyro_data[0]);
   Serial.print("\t");
   Serial.print(gyro_data[1]);
   Serial.print("\t");
   Serial.print(gyro_data[2]);
   Serial.print("\n");
   delay(100);
void i2c_write(int address, byte reg, byte data) {
  Wire.beginTransmission(address);
  Wire.write(reg);
  Wire.write(data);
  Wire.endTransmission();
void i2c_read(int address, byte reg, int count, byte* data) {
 int i = 0;
 Wire.write(reg);
 Wire.requestFrom(address,count);
 while(Wire.available()){
   c = Wire.read();
   data[i] = c;
   i++;
void init_adxl345() {
  byte data = 0;
  i2c_write(ADXL345_ADDRESS, ADXL_REGISTER_PWRCTL, ADXL_PWRCTL_MEASURE);
  i2c_read(ADXL345_ADDRESS, ADXL_REGISTER_PWRCTL, 1, &data);
  Serial.println((unsigned int)data);
void read_adxl345() {
 byte bytes[6];
 memset(bytes,0,6);
 i2c_read(ADXL345_ADDRESS, ADXL345_REGISTER_XLSB, 6, bytes);
 for (int i=0;i<3;++i) {
 accelerometer_data[i] = (int)bytes[2*i] + (((int)bytes[2*i + 1]) << 8);
void init_itg3200() {
  byte data = 0;
  i2c_write(ITG3200_ADDRESS, ITG3200_REGISTER_DLPF_FS, ITG3200_FULLSCALE | ITG3200_42HZ);
  i2c_read(ITG3200_ADDRESS, ITG3200_REGISTER_DLPF_FS, 1, &data);
void read_itg3200() {
  byte bytes[6];
  memset(bytes,0,6);
  i2c_read(ITG3200_ADDRESS, ITG3200_REGISTER_XMSB, 6, bytes);
  gyro_data[i] = (int)bytes[2*i + 1] + (((int)bytes[2*i]) << 8);
void init_hmc5843() {
  byte data = 0;
  i2c_write(HMC5843_ADDRESS, HMC5843_REGISTER_MEASMODE, HMC5843_MEASMODE_CONT);
  i2c_read(HMC5843_ADDRESS, HMC5843_REGISTER_MEASMODE, 1, &data);
void read_hmc5843() {
 byte bytes[6];
 memset(bytes,0,6);
 i2c_read(HMC5843_ADDRESS, HMC5843_REGISTER_XMSB, 6, bytes);
 magnetometer_data[i] = (int)bytes[2*i + 1] + (((int)bytes[2*i]) << 8);
