9DOF to OSC
Hello,
here my specs:
Arduino Nano
Nano V3 Ethernet Shield W5500 (V3)
9DOF Sensor
Status:
Sending OSC Values over Ethernet Works
Sending Acceleration values over Serial USB Works
Sending Acceleration values over Ethernet OSC doesnt work
I tried so many different variations and can't find the mistake.
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
#include <OSCBundle.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_LSM303_U.h>
#include <Adafruit_L3GD20_U.h>
#include <Adafruit_9DOF.h>
 /* Assign a unique ID to the sensors */
Adafruit_LSM303_Accel_Unified accel = Adafruit_LSM303_Accel_Unified(30301);
Adafruit_LSM303_Mag_Unified   mag   = Adafruit_LSM303_Mag_Unified(30302);
Adafruit_L3GD20_Unified       gyro  = Adafruit_L3GD20_Unified(20);
EthernetUDP Udp;
//the Arduino's IP
IPAddress ip(192, 168, 8, 177);
//destination IP
IPAddress outIp(192, 168, 8, 62);
const unsigned int outPort = 8000;
byte mac[] = {
 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // you can find this written on the board of some Arduino Ethernets or shields
 Ethernet.begin(mac,ip);
 Udp.begin(8888);
void loop(){
 //declare the bundle
   OSCBundle bndl;
   sensors_event_t event;
    mag.getEvent(&event);
   //BOSCBundle's add' returns the OSCMessage so the message's 'add' can be composed together
   bndl.add("/analog/0").add((float)event.magnetic.x);
   bndl.add("/analog/1").add((float)analogRead(1));
  // bndl.add("/digital/5").add((digitalRead(5)==HIGH)?"HIGH":"LOW");
   //bndl.add("/mouse/step").add((float)analogRead(0)).add((float)analogRead(1));
   //bndl.add("/units").add("pixels");
   Udp.beginPacket(outIp, outPort);
       bndl.send(Udp); // send the bytes to the SLIP stream
   Udp.endPacket(); // mark the end of the OSC Packet
   bndl.empty(); // empty the bundle to free room for a new on
   delay(100);
Any Ideas for this?
the magnetic.x Value is not added in the bundle
Thanks <3 Christian
Reading the 9DOF Sensor Works:
#include <Wire.h>
void displaySensorDetails(void)
sensor_t sensor;
accel.getSensor(&sensor);
Serial.println(F("----------- ACCELEROMETER ----------"));
Serial.print  (F("Sensor:       ")); Serial.println(sensor.name);
Serial.print  (F("Driver Ver:   ")); Serial.println(sensor.version);
Serial.print  (F("Unique ID:    ")); Serial.println(sensor.sensor_id);
Serial.print  (F("Max Value:    ")); Serial.print(sensor.max_value); Serial.println(F(" m/s^2"));
Serial.print  (F("Min Value:    ")); Serial.print(sensor.min_value); Serial.println(F(" m/s^2"));
Serial.print  (F("Resolution:   ")); Serial.print(sensor.resolution); Serial.println(F(" m/s^2"));
Serial.println(F("------------------------------------"));
Serial.println(F(""));
gyro.getSensor(&sensor);
Serial.println(F("------------- GYROSCOPE -----------"));
Serial.print  (F("Max Value:    ")); Serial.print(sensor.max_value); Serial.println(F(" rad/s"));
Serial.print  (F("Min Value:    ")); Serial.print(sensor.min_value); Serial.println(F(" rad/s"));
Serial.print  (F("Resolution:   ")); Serial.print(sensor.resolution); Serial.println(F(" rad/s"));
mag.getSensor(&sensor);
Serial.println(F("----------- MAGNETOMETER -----------"));
Serial.print  (F("Max Value:    ")); Serial.print(sensor.max_value); Serial.println(F(" uT"));
Serial.print  (F("Min Value:    ")); Serial.print(sensor.min_value); Serial.println(F(" uT"));
Serial.print  (F("Resolution:   ")); Serial.print(sensor.resolution); Serial.println(F(" uT"));
void setup(void)
Serial.println(F("Adafruit 9DOF Tester")); Serial.println("");
/* Initialise the sensors */
if(!accel.begin())
  /* There was a problem detecting the ADXL345 ... check your connections */
  Serial.println(F("Ooops, no LSM303 detected ... Check your wiring!"));
  while(1);
if(!mag.begin())
  /* There was a problem detecting the LSM303 ... check your connections */
  Serial.println("Ooops, no LSM303 detected ... Check your wiring!");
  while(1);
if(!gyro.begin())
  /* There was a problem detecting the L3GD20 ... check your connections */
  Serial.print("Ooops, no L3GD20 detected ... Check your wiring or I2C ADDR!");
  while(1);
/* Display some basic information on this sensor */
displaySensorDetails();
void loop(void)
/* Get a new sensor event */
/* Display the results (acceleration is measured in m/s^2) */
accel.getEvent(&event);
Serial.print(F("ACCEL "));
Serial.print("X: "); Serial.print(event.acceleration.x); Serial.print("  ");
Serial.print("Y: "); Serial.print(event.acceleration.y); Serial.print("  ");
Serial.print("Z: "); Serial.print(event.acceleration.z); Serial.print("  ");Serial.println("m/s^2 ");
/* Display the results (magnetic vector values are in micro-Tesla (uT)) */
Serial.print(F("MAG   "));
Serial.print("X: "); Serial.print(event.magnetic.x); Serial.print("  ");
Serial.print("Y: "); Serial.print(event.magnetic.y); Serial.print("  ");
Serial.print("Z: "); Serial.print(event.magnetic.z); Serial.print("  ");Serial.println("uT");
/* Display the results (gyrocope values in rad/s) */
gyro.getEvent(&event);
Serial.print(F("GYRO  "));
Serial.print("X: "); Serial.print(event.gyro.x); Serial.print("  ");
Serial.print("Y: "); Serial.print(event.gyro.y); Serial.print("  ");
Serial.print("Z: "); Serial.print(event.gyro.z); Serial.print("  ");Serial.println("rad/s ");
Sending OSC works with this
#include <SPI.h>
EthernetUDP Udp;
//the Arduino's IP
IPAddress ip(128, 32, 122, 252);
//destination IP
IPAddress outIp(128, 32, 122, 125);
const unsigned int outPort = 9999;
byte mac[] = {
Udp.begin(8888);
void loop(){
  OSCBundle bndl;
  bndl.add("/analog/0").add((int32_t)analogRead(0));
  bndl.add("/analog/1").add((int32_t)analogRead(1));
  bndl.empty(); // empty the bundle to free room for a new one
Please edit your posts to add code tags.
jremington:
thanks, alright
The getEvent() method returns a bool validity flag - you should be checking if the result is valid:
    if (!mag.getEvent(&event))
      Serial.println ("Failed to read magnetometer") ;
      return;
Perhaps this is why you're not seeing data?
@markT
YES!!! Thanks so much!!!! that's is it!!!!!
:smiley: ;D :smiley: :smiley: :smiley: :smiley: :smiley: :smiley:
