9E+99 (VB to C++... arduino...)
Good morning
I'm recreating a formula on Arduino that I already have on VB6. My var on var have a value of '9E+99' ... it means that I have 99 leading zeros... 9000000(0)...
How can I recreate it on Arduino?
Thanks on advance Best regards Pedro Ferrer
It's afternoon here. 8)
Cek this out: http://arduino.cc/playground/Main/Fscale using 9*10(pow(99))
I guess :drooling_face:
Hello (It's better... :) )
Thanks by your prompt answer! I'll test as soon as possible.
Thanks once again Best regards Pedro Ferrer
Without the use of a special library you can’t. The largest floating-point number that can be represented is…
#define FLT_MAX 3.40282347e+38F
Those are trailing zeroes.
That number represents more than a billion time the number of fundamental particles in the observable universe.
Use the number with Arduino for mathematical purpose maybe..in order to predict future..WOW Waiting for the resutl!
I suspect you will be disappointed.
Hello
What I miss?...
Well, so... I have to use '#define FLT_MAX 3.40282347e+38F' instead '9*10(pow(99))' ?
Please let me know Thanks on advance Best regards Pedro Ferrer
You missed the fact that you can't define a number that large, without using a library. That #define shows the largest float value that can be created, and 3.4e+38 is nowhere near 9e+99.
I would be interested in what the number represents, or is this a purely hypothetical exercise?
Given that you could express the age of the universe in Planck Times many billions of times over in a number this large, I think it is safe to assume it is an exercise.
I'm sure it's a hypothetical number, similar to 9/9/99 as a dummy date (we used that a few years ago)
If there's a real problem around this, it's probably related to the fact that a double on Arduino is 32 bit only and thus the same as a (single) float.
Hello
The var is called 'Bogus'.. the name tells almost everything... It's used on comparison with other value... a Julian Date :)
So I have to use:
define bogus 3.4e+38
That's it
Thanks Best regards
So I have to use:
Or -1, since dates can't be negative.
1) what about 3e+33 It's beyond any real physical value ( in realistic units )
2) how can you safely compare dates with float ( or double ) numbers ?
Hello
michael_x: 2) how can you safely compare dates with float ( or double ) numbers ?
Please check this calculator... http://aa.usno.navy.mil/data/docs/JulianDate.php
how can you safely compare dates with float ( or double ) numbers ? Please check this calculator... http://aa.usno.navy.mil/data/docs/JulianDate.php
So you can't, on an Arduino, even if you stick to full days
The Julian date for CE 2012 May 23 00:00:00.0 UT is JD 2456070.500000
This is way beyond the accuracy of a 32 bit float
BTW: Curious about the used formula,why is a Julian Date related to a pacific timezone ?
Hello
Yes... if you want to retrieve seconds, minutes and hours from there, forget it with arduino (for now... with chipkit is possible, I think)... but days, months and years... are fine :)
Hello
That's why we don't use that kind of valour... but shorter... eg: Julian date year 2000... is shorter... about 41xxx.xxxx days... until now...
Bye Pedro Ferrer
