9pin D sub to 7 pin DIN
I was wondering how to connect the 2 connectors (9pin d sub and 7 pin din) to make it possible to receive data from the 1 to the other connector.
Thanks
7-pin DIN sounds unlikely - what was this connected to ?
MarkT:
I’ve a 7 pin DIN plug and socket, bought from Farnell/Element14 (order code 1321479 for the plug) about 2 months ago. There are two types. One with 6 pins @ 30o and a central 7th pin, the other with 7 pins in an arc around the edge like the 5 pin audio DIN plugs. NB, these are full size (about 1/2" dia), not mini DIN plugs.
MarkT: 7-pin DIN sounds unlikely - what was this connected to ?
It is a 7-pin Din with the 7 pins in an arc. It is as serial out on a weighing computer. I would like to send the data from there to the pc to get the data easy.
But now the question, how to connect the wires? Is it just the Rx,Tx and Ground?
7pin DIN is non-standard, afaik. You need to consult the weighing computer manual.
