So, given the question:
but doesn't say anything about the mA... so i don't know which one to get, since they have several different models with different mA or mW... so please advice
what is a reasonable answer?
Surely we can give some consistent advice to folks looking for an answer?
I will stick to lower-end 500mA based on my logic above. The rationale is that if you build something powered from USB, then you might like to run the same thing from the adapter, and you might get grumpy (no disrespect
if it doesn't work.
Accepting Grump_Mike's helpful reminder that more power isn't automatically safer, there isn't a lot of point having oodles of power just waiting to melt something, so 500mA is enough for folks who use a USB-based development approach.
Pluggy observes that the Arduino itself only pulls 30mA, so if you feel that you are only going to run the Arduino with minimal external electronics, even lower current would be better.
EDIT: I've always been taught to have some headroom for power, up to 2x. The rationale includes: estimates might have small errors, start-up power can exceed the average, circumstances change, and it'd be annoying to have to change power supply because of a small change, heat damages parts, so running something at half capacity allows the thing to stay away from its maximum temperature, and hence should last longer.
So if you are calculating the power output of your power supply, give yourself upto 2x headroom, and multiply your estimate by 2.
Having said all that, 1A 9V supplies are dirt cheap ($3.50), and work fine.
The calculation of power is: Power = Voltage * Current, so
Power = 5V * 0.5A = 2.5W,
Power = 5V * 1A = 5W,
Power = 5V * 0.03 (30 mA) = 0.15W, or 150mW
The amount of power consumed is based on the amount of current that the Arduino and electronics uses, and not the rating of the adapter.
There will be some losses in the adapter, and these can vary. So you may find that an adapter rated at 150mA actually waste more power than one rated at 0.5A. Efficiency is based on the technology and quality of its implementation, not its rating.
(I would expect the adapter to be optimised for its rated power output, so don't go crazy and get a 88% efficient 100A power supply and feel disappointed that it seems to use more power than a notionally 70% efficient adapter rated at 200mA.)
I'm sure folks can improve this suggestion. I am not saying this is definitive. But may I ask that we try to summaries for the poor souls trying to understand, so they get a clear-ish view, at least of this thread, in one spot? (IMHO, the time to find something as concrete and direct as this should be small).
HTH
GB-)
