9V motor but only use 6V in voltmeter
I buy 9v motor and put it in my arduino, but the motor run quite slow and when i check with voltmeter just 6 volt. Any idea how to increase the motor speed? or maximise the voltage to 9v?
My motor is micro metal gear 1000 rpm with torque 0.2kg/cm
Did it friend the other 3 volts on facebook first :wink: JK.
Ok so we know nothing about the power supply being used ?
We dont have your schematic ?
Those are the first order of business.
What motor? That means a link to the data for it, not just a brief description in words.
What motor driver?
What power supply?
Code?
ballscrewbob:
im just using 9v battery connect to arduino and another 9v
battery connect to l298n dual motor controller 2A
My code:
///Define port line sensor
//in serial printing, bila kena black = 0, kalau white = 1
#define LS A1
#define LCS A2
#define CS A3
#define RCS A4
#define RS A5
//motor kiri
#define enA 2
#define in1 3
#define in2 4
//motor kanan
#define enB 7
#define in3 5
#define in4 6
pinMode(LS, INPUT);
pinMode(RS, INPUT);
pinMode(CS, INPUT);
pinMode(RCS, INPUT);
pinMode(LCS, INPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
if((digitalRead(CS)==0)) // Condition_1 stop
forward();
else if((digitalRead(CS)==1) && (digitalRead(RCS)==1)) //CONDITION-2 FORWRD
left();
else if((digitalRead(CS)==1) && (digitalRead(RS)==1)) // RIGHT
left();
else if((digitalRead(CS)==1) && (digitalRead(LCS)==1))
right();
right();
void right() {
analogWrite(enA,255);
analogWrite(enB,255);
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
void Stop () {
analogWrite(enA, 0);
analogWrite(enB, 0);
digitalWrite(in1, LOW);
digitalWrite(in3, LOW);
void left() {
analogWrite(enA, 255);
analogWrite(enB, 255);
digitalWrite(in2, HIGH);
digitalWrite(in4, HIGH);
void forward() {
void back(){
digitalWrite(in2,HIGH);
And a common GROUND ?
BTW most regular 9V batteries do not last very long at all with motors and drain exceptionally quickly.
We still know nothing about the motor itself ?
https://nadieleczone.com.my/webshaper/store/viewProd.asp?pkProductItem=447
i bought it from this site you can check it out
Operating voltage : 3v -12v (Rated 6v)
Speed : 1000RPM (rotate per min )
Torque : 0.2kg.cm
Ampere : 40ma (No load) , 600ma (Stall)
Please answer ALL the questions in replies #1 and #2, and post a wiring diagram (hand drawn, not Fritzing).
Use code tags ("</>") when posting code.
