I am a newbie. I have never created a project but like to program in Python.
Here it goes...I would like to create a saucer that has LEDs that show the direction of a tilt (some angle variance) and movement in a direction if it moves beyond it's starting position.
Basically a visual (or audible) indication that we have moved or tilted too much.
curious18:
So now is your chance to learn C and C++.
curious18:
That part is relatively easy. As the accelerometer tilts, the portion of the force of gravity acting on each of the three axes will shift. Some math will tell youhow far and in which direction the saucer has tilted.
curious18:
That's going to be harder. The accelerometer will tell you how quickly your speed is changing. It won't tell you speed or position. Knowing your position is a very difficult problem.
Thanks everyone for your kind words. Except for bluejets of course who apparently has social issues. Bluejets, try to be a little nicer to newbies next time and not pretend that you are more clever than you actually are. Just a note for the next time you are scolding people, it may help if the link you attached actually worked! Try clicking on source code among others and you will find it is long, long expired.
If you are looking to program in Python, take a look at the Adafruit CircuitPython boards such as the following. You get a lot of hardware (SAMD, RGB LEDs, accel, DAC+speaker, etc.) on one board. And it can be programmed using Arduino as well. It is designed for anyone new to electronics and embedded software.
curious18:
No, on the contrary, I'm known for my good social skills as well as my knowledge which I try to pass on.
In this instance I stated the obvious, short and sweet and moved on.
As for the link, I always try it before and after I post and it worked fine.
If you have problems then it's not from this end I can assure you.
