It would be much easier to increase the number of servos if the author had use arrays instead of four different names.
Did you need the OLED display?
The sketch can only store eight positions. Is that enough? How many positions do you need to store?
Here is the original sketch:
#include <Servo.h>
#include <OLED_I2C.h>
//define the servos
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
OLED myOLED(SDA, SCL);
extern uint8_t SmallFont[];
//define the buttons
const int button1 = 12;
const int button2 = 13;
//define variable for values of the button
int button1Pressed = 0;
boolean button2Pressed = false;
//define potentiometers
const int pot1 = A1;
const int pot2 = A2;
const int pot3 = A3;
const int pot4 = A4;
//define variable for values of the potentiometers
int pot1Val;
int pot2Val;
int pot3Val;
int pot4Val;
//define variable for angles of the potentiometer
int pot1Angle;
int pot2Angle;
int pot3Angle;
int pot4Angle;
//define variable for saved position of the servos
int servo1PosSave[] = {1, 1, 1, 1, 1, 1, 1, 1};
int servo2PosSave[] = {1, 1, 1, 1, 1, 1, 1, 1};
int servo3PosSave[] = {1, 1, 1, 1, 1, 1, 1, 1};
int servo4PosSave[] = {1, 1, 1, 1, 1, 1, 1, 1};
myOLED.begin();
myOLED.setFont(SmallFont);
//define attached pins of the servos
servo1.attach(3);
servo2.attach(4);
servo3.attach(5);
servo4.attach(6);
//define buttons as input units
pinMode(button1, INPUT);
pinMode(button2, INPUT);
servo1.write(90);
servo2.write(90);
servo3.write(90);
servo4.write(90);
myOLED.clrScr();
myOLED.print("MERT ARDUINO AND TECH", CENTER, 8);
myOLED.print("PRESS TO SAVE BUTTON", CENTER, 42);
myOLED.update();
//read the potentiometer values and define the servo angle to
//the potentiometer value with the map function
pot1Val = analogRead(pot1);
pot1Angle = map (pot1Val, 0, 1023, 10, 179);
pot2Val = analogRead(pot2);
pot2Angle = map (pot2Val, 0, 1023, 10, 150);
pot3Val = analogRead(pot3);
pot3Angle = map (pot3Val, 0, 1023, 10, 170);
pot4Val = analogRead(pot4);
pot4Angle = map (pot4Val, 0, 1023, 10, 170);
//servos move to mapped angles
servo1.write(pot1Angle);
servo2.write(pot2Angle);
servo3.write(pot3Angle);
servo4.write(pot4Angle);
//if button1 is pressed (HIGH), save the potentiometers position
//as long as button1 is pressed
if (digitalRead(button1) == HIGH)
button1Pressed++;
switch (button1Pressed)
case 1:
servo1PosSave[0] = pot1Angle;
servo2PosSave[0] = pot2Angle;
servo3PosSave[0] = pot3Angle;
servo4PosSave[0] = pot4Angle;
Serial.println("Position #1 Saved");
myOLED.clrScr();
myOLED.print("POSITION #1 SAVED", CENTER, 42);
myOLED.update();
delay(1500);
case 2:
servo1PosSave[1] = pot1Angle;
servo2PosSave[1] = pot2Angle;
servo3PosSave[1] = pot3Angle;
servo4PosSave[1] = pot4Angle;
Serial.println("Position #2 Saved");
myOLED.clrScr();
myOLED.print("POSITION #2 SAVED", CENTER, 42);
myOLED.update();
delay(1500);
case 3:
servo1PosSave[2] = pot1Angle;
servo2PosSave[2] = pot2Angle;
servo3PosSave[2] = pot3Angle;
servo4PosSave[2] = pot4Angle;
Serial.println("Position #3 Saved");
myOLED.clrScr();
myOLED.print("POSITION #3 SAVED", CENTER, 42);
myOLED.update();
delay(1500);
case 4:
servo1PosSave[3] = pot1Angle;
servo2PosSave[3] = pot2Angle;
servo3PosSave[3] = pot3Angle;
servo4PosSave[3] = pot4Angle;
Serial.println("Position #4 Saved");
myOLED.clrScr();
myOLED.print("POSITION #4 SAVED", CENTER, 42);
myOLED.update();
delay(1500);
case 5:
servo1PosSave[4] = pot1Angle;
servo2PosSave[4] = pot2Angle;
servo3PosSave[4] = pot3Angle;
servo4PosSave[4] = pot4Angle;
Serial.println("Position #5 Saved");
myOLED.clrScr();
myOLED.print("POSITION #5 SAVED", CENTER, 42);
myOLED.update();
delay(1500);
case 6:
servo1PosSave[5] = pot1Angle;
servo2PosSave[5] = pot2Angle;
servo3PosSave[5] = pot3Angle;
servo4PosSave[5] = pot4Angle;
Serial.println("Position #6 Saved");
myOLED.clrScr();
myOLED.print("POSITION #6 SAVED", CENTER, 42);
myOLED.update();
delay(1500);
case 7:
servo1PosSave[6] = pot1Angle;
servo2PosSave[6] = pot2Angle;
servo3PosSave[6] = pot3Angle;
servo4PosSave[6] = pot4Angle;
Serial.println("Position #7 Saved");
myOLED.clrScr();
myOLED.print("POSITION #7 SAVED", CENTER, 42);
myOLED.update();
delay(1500);
case 8:
servo1PosSave[7] = pot1Angle;
servo2PosSave[7] = pot2Angle;
servo3PosSave[7] = pot3Angle;
servo4PosSave[7] = pot4Angle;
Serial.println("Position #8 Saved");
myOLED.clrScr();
myOLED.print("POSITION #8 SAVED", CENTER, 28);
myOLED.print("PRESS TO MOVE BUTTON", CENTER, 42);
myOLED.update();
delay(1500);
//if button2 pressed (HIGH), the servos move saved position
if (digitalRead(button2) == HIGH)
button2Pressed = true;
if (button2Pressed)
for (int i = 0; i < 8; i++)
servo1.write(servo1PosSave[i]);
servo2.write(servo2PosSave[i]);
servo3.write(servo3PosSave[i]);
servo4.write(servo4PosSave[i]);
myOLED.clrScr();
myOLED.print("MOVING...", CENTER, 42);
myOLED.update();
delay(2000);
delay(100);
