If I have a 2.3 to 2.4A total circuit load will a 2.5A wall adapter power supply be sufficient, or is that running it too close to capacity and I should use a 3A one?
Also as I google around I see some schematics with larger (100uF - 4700uF) bypass capacitors near the power socket, and some with none...I know about placing 0.1uF decoupling caps near the ICs, but how do you know if you need a bigger bypass capacitor, and what value to use? If it matters, I'm using a regulated switching supply.
Thanks as always.
