A/D reading low
I've been beating my head against this for a day or two, and I am stumped.
I am trying to measure car battery voltage.
I have a simple voltage divider with 47K and 20K resistors. I have a 1.5uF cap to ground as well to filter noise (I have a lot of noise at 1.5Khz and 3Khz). This is connected to an A/D pin.
With 12.7V input, I should be getting a reading of:
1024 * (12.7 / 5) * 20 / (47 + 20) = 776.
I'm consistently getting readings of about 713.
I've checked everything I can think of. I checked Vcc; it's 5.03V.
I even added this code:
http://hacking.majenko.co.uk/making-accurate-adc-readings-on-arduino
No joy.
The voltage is steady (it's connected to a 225Ah battery). Could the cap be pulling down the voltage? It doesn't seem to make sense.
No.
So what tolerance are these resistors?
If each one was at the wrong end your divider could be off. I haven't worked it out because I don't know what tolerance you are using, but it feels like this is the problem.
Crap. Thanks for pointing out the obvious. I would have sworn I got 1% but I just checked the data sheet and they're 5%. Still, it seems to be a lot.
I also have a 5V zener to ground paralleling the cap. Could that make a difference? The leakage is on the order of 50nA, so it should be orders of magnitude less than the .2mA across the resistors.
Yes it could. The knee on zenners is not so sharp so you could be getting a lot more current down it than you think.
Leakage current is often for the reverse bias case, are you sure that it is so small for forward bias.
I can always build another board with no zeners. Or clip this one off and test. I'm going back and forth on the zeners.
I need something to protect against load dumps but zeners just seem to have a lot of issues.
Yes zenners are fine on a digital input but have issues with an analogue one. I would use clamping diodes to the rails.
OK, I started a new thread on protecting analog inputs.
http://forum.arduino.cc/index.php?topic=181624.0
