A few brief general questions about variables in a class
Just began using classes, based off of the LibraryTutorial. Some of the parts to be accomplished in my project aren't included in the tutorial, and I'm having a hard time finding the answers elsewhere:
  1. What is the difference between using a private variable in the header file, and declaring a variable outside of any functions in the .cpp file?
  2. Why is it necessary to add the size of an array when declaring one as a private variable? Asking this just in case private arrays behave differently (who knows, I'm learning new stuff every day). For example, I get an error when my array looks like this:
uint8_t myArray[] = {1, 2, 3};
but this works:
uint8_t myArray[3] = {1, 2, 3};
Still a noob. Thanks for the help.
  1. If you define a variable ONLY in the .cpp file, it is NOT a class variable. ONLY variables defined INSIDE the class definition (which typically resides in in the .h file) are members of that class. Anything else is just a regular (usually global) variable.
  2. Your two examples are precisely the same. Both will create arrays of length 3. You CANNOT define a class member array without defining the length of the array by either of the methods you show.
What error did you get with the first array declaration?
Thanks for the replies, all.
This was the error that came up:
too many initializers for 'int [0]'
