A few issues compiling code
I'm working on a project and it utilizes THIS code.
I've gotten all the libraries setup and now its compile time. The first error I get is a use of deleted function for
ESP8266WebServer server = ESP8266WebServer(HTTP_PORT);
per a post online I was able to get this working by changing it to ESP8266WebServer(HTTP_PORT); but I don't understand why this is having a problem now when it compiled correctly when it was put on the board.
The next error after fixing that was expected unqualified-id before numeric constant for #define HTTP_PORT 80
This error I don't get because i've looked at several code blocks and none seem to require parentheses when defining a variable like this. the only thing I can think of is that when I look at the other defined variables, all of them are used in the function setup()
The last error so far is server not defined in scope. I'm almost certain this is because it was defined in
which was removed when I changed it to ESP8266WebServer(HTTP_PORT);
floridaman:61: error: expected unqualified-id before numeric constant
/home/crasis/Arduino/floridaman-master/floridaman/floridaman.ino:74:18: note: in expansion of macro 'HTTP_PORT'
floridaman:61: error: expected ')' before numeric constant
/home/crasis/Arduino/floridaman-master/floridaman/floridaman.ino: In function 'void setup()':
floridaman:95: error: 'server' was not declared in this scope
   server.on("/", srv_handle_index_html);
/home/crasis/Arduino/floridaman-master/floridaman/floridaman.ino: In function 'void loop()':
floridaman:109: error: 'server' was not declared in this scope
   server.handleClient();
/home/crasis/Arduino/floridaman-master/floridaman/floridaman.ino: In function 'void srv_handle_not_found()':
floridaman:186: error: 'server' was not declared in this scope
   server.send(404, "text/plain", "File Not Found");
/home/crasis/Arduino/floridaman-master/floridaman/floridaman.ino: In function 'void srv_handle_index_html()':
floridaman:190: error: 'server' was not declared in this scope
   server.send_P(200,"text/html", index_html);
/home/crasis/Arduino/floridaman-master/floridaman/floridaman.ino: In function 'void srv_handle_main_js()':
floridaman:194: error: 'server' was not declared in this scope
   server.send_P(200,"application/javascript", main_js);
/home/crasis/Arduino/floridaman-master/floridaman/floridaman.ino: In function 'void srv_handle_modes()':
floridaman:198: error: 'server' was not declared in this scope
   server.send(200,"text/plain", modes);
/home/crasis/Arduino/floridaman-master/floridaman/floridaman.ino: In function 'void srv_handle_set()':
floridaman:202: error: 'server' was not declared in this scope
   for (uint8_t i = 0; i < server.args(); i++) {
floridaman:237: error: 'server' was not declared in this scope
   server.send(200, "text/plain", "OK");
exit status 1
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
We need to see your complete code.
Thanks.. Tom.. :slight_smile:
look at the statements before
to see if there are errors which cause this message to appear in this line
it is best to post all your code
Just some include statements and library files
  WS2812FX Webinterface.
  Harm Aldick - 2016
  www.aldick.org
  FEATURES
    * Webinterface with mode, color, speed and brightness selectors
  LICENSE
  The MIT License (MIT)
  Copyright (c) 2016  Harm Aldick
  Permission is hereby granted, free of charge, to any person obtaining a copy
  of this software and associated documentation files (the "Software"), to deal
  in the Software without restriction, including without limitation the rights
  to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
  copies of the Software, and to permit persons to whom the Software is
  furnished to do so, subject to the following conditions:
  The above copyright notice and this permission notice shall be included in
  all copies or substantial portions of the Software.
  THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
  IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
  FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
  AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
  LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
  OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
  THE SOFTWARE.
  CHANGELOG
  2016-11-26 initial version
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <WS2812FX.h>
#include "index.html.h"
#include "main.js.h"
// CHANGE ME FOR SUPER FUN TIME
#define WIFI_SSID "GatorNet"
#define WIFI_PASSWORD "iliketoparty"
#define min(a,b) ((a)<(b)?(a):(b))
#define max(a,b) ((a)>(b)?(a):(b))
#define LED_PIN D2
#define LED_COUNT 6
// checks WiFi every 30s
#define WIFI_TIMEOUT 30000
// Thats right, a port is open
#define DEFAULT_COLOR 0x00FF00
#define DEFAULT_BRIGHTNESS 31
#define BRIGHTNESS_STEP 15
#define SPEED_STEP 10
#define DEFAULT_SPEED 50
#define DEFAULT_MODE FX_MODE_TWINKLE_FADE_RANDOM
unsigned long last_wifi_check_time = 0;
String modes = "";
WS2812FX ws2812fx = WS2812FX(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
void setup(){
  banner();
  modes.reserve(5000);
  modes_setup();
  Serial.println("WS2812FX setup");
  ws2812fx.init();
  ws2812fx.setMode(DEFAULT_MODE);
  ws2812fx.setColor(DEFAULT_COLOR);
  ws2812fx.setSpeed(DEFAULT_SPEED);
  ws2812fx.setBrightness(DEFAULT_BRIGHTNESS);
  ws2812fx.start();
  Serial.println("Wifi setup");
  wifi_setup();
  Serial.println("HTTP server setup");
  server.on("/main.js", srv_handle_main_js);
  server.on("/modes", srv_handle_modes);
  server.on("/set", srv_handle_set);
  server.onNotFound(srv_handle_not_found);
  server.begin();
  Serial.println("HTTP server started.");
  Serial.println("ready!");
  unsigned long now = millis();
  ws2812fx.service();
  if(now - last_wifi_check_time > WIFI_TIMEOUT) {
    Serial.print("Checking WiFi... ");
    if(WiFi.status() != WL_CONNECTED) {
      Serial.println("WiFi connection lost. Reconnecting...");
      wifi_setup();
      Serial.println("OK");
    last_wifi_check_time = now;
void wifi_setup() {
  Serial.print("Connecting to ");
  Serial.println(WIFI_SSID);
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  WiFi.mode(WIFI_STA);
  unsigned long connect_start = millis();
  while(WiFi.status() != WL_CONNECTED) {
    delay(50);
    ws2812fx.service();
    if(millis() - connect_start > WIFI_TIMEOUT) {
      Serial.print("Tried ");
      Serial.print(WIFI_TIMEOUT);
      Serial.print("ms. Resetting ESP now.");
      ESP.reset();
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print("IP address: ");
void banner() {
  Serial.println("");
  Serial.println(" █████▒██▓     ▒█████   ██▀███   ██▓▓█████▄  ▄▄▄          ███▄ ▄███▓  ▄▄▄       ███▄    █ ");
  Serial.println("▓██   ▒▓██▒    ▒██▒  ██▒▓██ ▒ ██▒▓██▒▒██▀ ██▌ ▒████▄       ▓██▒▀█▀ ██▒▒ ████▄     ██ ▀█   █ ");
  Serial.println("▒████ ░▒██░    ▒██░  ██▒▓██ ░▄█ ▒▒██▒░██   █▌ ▒██  ▀█▄     ▓██    ▓██░▒██  ▀█▄  ▓██  ▀█ ██▒");
  Serial.println("░▓█▒  ░▒██░    ▒██   ██░▒██▀▀█▄  ░██░░▓█▄   ▌░██▄▄▄▄██     ▒██    ▒██ ░██▄▄▄▄██ ▓██▒  ▐▌██▒");
  Serial.println("░▒█░   ░██████▒░ ████▓▒░░██▓ ▒██▒░██░░▒████▓  ▓█   ▓██▒    ▒██▒   ░██▒ ▓█   ▓██▒▒██░   ▓██░");
  Serial.println(" ▒ ░   ░ ▒░▓  ░░ ▒░▒░▒░ ░ ▒▓ ░▒▓░░▓   ▒▒▓  ▒  ▒▒   ▓▒█░   ░ ▒░   ░  ░ ▒▒   ▓▒█░░ ▒░   ▒ ▒ ");
  Serial.println(" ░     ░ ░ ▒  ░  ░ ▒ ▒░   ░▒ ░ ▒░ ▒ ░ ░ ▒  ▒   ▒   ▒▒ ░   ░  ░      ░  ▒   ▒▒ ░░ ░░   ░ ▒░");
  Serial.println(" ░ ░     ░ ░   ░ ░ ░ ▒    ░░   ░  ▒ ░ ░ ░  ░   ░   ▒      ░      ░     ░   ▒      ░   ░ ░ ");
  Serial.println("           ░  ░    ░ ░     ░      ░     ░          ░  ░          ░         ░  ░         ░ ");
  Serial.println("                                      ░                                                   ");
  Serial.println("");
  Serial.println("Looking for Florida Man Party Access Point...");
// Build <li> string for all modes.
void modes_setup() {
  modes = "";
  for(uint8_t i=0; i < ws2812fx.getModeCount(); i++) {
    modes += "<li><a href='#' class='m' id='";
    modes += i;
    modes += "'>";
    modes += ws2812fx.getModeName(i);
    modes += "</a></li>";
#  Webserver Functions
void srv_handle_not_found() {
void srv_handle_index_html() {
void srv_handle_main_js() {
void srv_handle_modes() {
void srv_handle_set() {
    if (server.argName(i) == "c") {
      uint32_t tmp = (uint32_t) strtol(&server.arg(i)[0], NULL, 16);
      if (tmp >= 0x000000 && tmp <= 0xFFFFFF) {
        ws2812fx.setColor(tmp);
    if (server.argName(i) == "m") {
      uint8_t tmp = (uint8_t) strtol(&server.arg(i)[0], NULL, 10);
      ws2812fx.setMode(tmp % ws2812fx.getModeCount());
    if (server.argName(i) == "b") {
      if(server.arg(i)[0] == '-') {
        ws2812fx.decreaseBrightness(BRIGHTNESS_STEP);
      } else if(server.arg(i)[0] == ' ') {
        ws2812fx.increaseBrightness(BRIGHTNESS_STEP);
      ws2812fx.setBrightness(tmp);
    if (server.argName(i) == "s") {
        ws2812fx.decreaseSpeed(SPEED_STEP);
        ws2812fx.increaseSpeed(SPEED_STEP);
      ws2812fx.setSpeed(tmp);
bump
sephstorm:
bump
What new information have you added? In your initial post, you claimed that you changed a line that set up the server object, but the last code you posted does not reflect that.
Post the exact code you are trying to compile, and the EXACT error messages.
Long story short the problem was stemming from the first error, as expected.
Original code:
Which I changed to
It should have been
ESP8266WebServer server (HTTP_PORT);
I assume something changed in the a new version of the IDE so this was no longer accepted...
