A few PT100's and MAX31865
I'm newbie in Arduino and here. ::slight_smile:
I'm going to measure temperature by using RTD (PT100) and MAX31865 converter.
But, I have to use about 5(five) PT100 sensors.
So, the questions are:
  1. Is it possible? :astonished:
  2. How many MAX31865 converters I need to use, five?
  3. If I use five MAX31865, so how they all communicate by SPI with Arduino.
Thank you... :wink:
Is this a bare chip, or a breakout board.
Link?
It might have a CS (chip select) pin.
Leo..
Hi, Leo! :slight_smile:
Yes, it it a chip, 700-MAX31865AAP+,
Link to web page
and
MAX31865 datasheet
Juri..
No experience with this chip, but it has a CS (chip select) pin.
That can be used to select one chip on the same bus.
That CS line is also available on breakout boards.
Leo..
Hi guys,
As i can see, some of you have some experience with Max31865 RTD-to-Digital IC.
I'm designing a board with 12 converters.
My doubt: it is necessary to use DRDY pin ? I need to read the state of this pin to trigger an interrupt, maybe ?
Whats the real purpose of the DRDY pin ?
Thanks.
No, you can leave it disconnected. You just need to wait out the conversion time, vs waiting for it to go active & signal the conversion is done.
I put 15 on a board with none of them connected.
Try this sketch from Maxim for reading 1, put it in a loop to cycle thru all 12.
You have to put real #s in these 2 lines:
float Reference_Resistor; //Reference Resistor installed on the board.
float RTD_Resistance; //RTD Resistance at 0 Degrees. Please refer to your RTD data sheet.
This uses DRDY, adjust to wait it out if you don't use it.
max31865Hani.ino (9.97 KB)
I'm using a breakout board supplied by a company called playing with fusion it has 2 pt100/1000 inputs and has code on the site www.playingwithfusion.com
CrossRoads:
Have you run this code on an Arduino and does it work
