I just got my Arduino BT, and tried to hook it up to the transformator... i tested the voltage with a multimeter first and it said exactly 5,07V. The LED didnt light up... the website says 5,5V is the limit,but it didnt work... then i hooked it ut to two 1,5V batteries (around 3V together) and it worked... Why doesnt it work at 5V?
i wanna hook up a serial lcd on the arduino, and at the same time interface my comtuter over bluetooth... is that even possible, considering, that the pins 0 and 1 are actually connected to the bluetooth module... could this be done? or maybe solved with I2C? help me out pls
