A function-definition is not allowed here before '{' token error with almost no code to error on
I've been pulling my hair out trying to figure this out.
I'm using tabs in the Arduino IDE, and I have 2 of them.
One is a Command interpreter made for the Arduino that I heavily modified, called CommandLine.h.
The other one is the main .ino file.
All I have are just under 15 lines in the main file, and that's where the error is getting thrown.
Trying to upload the following code results in the IDE throwing an error.
#include "CommandLine.h"
void
setup() {
void
loop() {
  bool received = getCommandLineFromSerialPort(CommandLine);      //global CommandLine is defined in CommandLine.h
  if (received) DoMyCommand(CommandLine);
Uploading this code makes the IDE throw a fit and give me this error:
a function-definition is not allowed here before '{' token
If anyone could help me fix this, that would be great! I've tried Auto-Format, changing indents, adding brackets, removing brackets, and more.
Thanks!
I am betting your error message had a lot more to it than you are showing.
Post the entire error message, please.
The Entire Error output:
In file included from C:\Users\liljm\Documents\Arduino Projects\meccanoidG15\meccanoidG15.ino:1:0:
C:\Users\liljm\Documents\Arduino Projects\meccanoidG15\CommandLine.h: In function 'bool getCommandLineFromSerialPort(char*)':
C:\Users\liljm\Documents\Arduino Projects\meccanoidG15\CommandLine.h:143:43: warning: left shift count >= width of type [-Wshift-count-overflow]
           Serial << byte(BS) << byte(SPACE) << byte(BS);  //no idea how this works, found it on the Internet
C:\Users\liljm\Documents\Arduino Projects\meccanoidG15\meccanoidG15.ino: In function 'bool DoMyCommand(char*)':
meccanoidG15:3:9: error: a function-definition is not allowed here before '{' token
 setup() {
meccanoidG15:8:8: error: a function-definition is not allowed here before '{' token
 loop() {
meccanoidG15:11:1: error: expected '}' at end of input
exit status 1
I know but humor me with those changes.
Here is the entirety of CommandLine.h:
  How to Use CommandLine:
    Create a sketch.  Look below for a sample setup and main loop code and copy and paste it in into the new sketch.
   Create a new tab.  (Use the drop down menu (little triangle) on the far right of the Arduino Editor.
   Name the tab CommandLine.h
   Paste this file into it.
  Test:
     Download the sketch you just created to your Arduino as usual and open the Serial Window.  Typey these commands followed by return:
      add 5, 10
      subtract 10, 5
    Look at the add and subtract commands included and then write your own!
  Here's what's going on under the covers
  Simple and Clear Command Line Interpreter
     This file will allow you to type commands into the Serial Window like,
        add 23,599
        blink 5
        playSong Yesterday
     to your sketch running on the Arduino and execute them.
     Implementation note:  This will use C strings as opposed to String Objects based on the assumption that if you need a commandLine interpreter,
     you are probably short on space too and the String object tends to be space inefficient.
   1)  Simple Protocol
         Commands are words and numbers either space or comma spearated
         The first word is the command, each additional word is an argument
         "\n" terminates each command
   2)  Using the C library routine strtok:
       A command is a word separated by spaces or commas.  A word separated by certain characters (like space or comma) is called a token.
       To get tokens one by one, I use the C lib routing strtok (part of C stdlib.h see below how to include it).
           It's part of C language library <string.h> which you can look up online.  Basically you:
              1) pass it a string (and the delimeters you use, i.e. space and comman) and it will return the first token from the string
              2) on subsequent calls, pass it NULL (instead of the string ptr) and it will continue where it left off with the initial string.
        I've written a couple of basic helper routines:
            readNumber: uses strtok and atoi (atoi: ascii to int, again part of C stdlib.h) to return an integer.
              Note that atoi returns an int and if you are using 1 byte ints like uint8_t you'll have to get the lowByte().
            readWord: returns a ptr to a text word
   4)  DoMyCommand: A list of if-then-elses for each command.  You could make this a case statement if all commands were a single char.
      Using a word is more readable.
          For the purposes of this example we have:
              Add
              Subtract
              nullCommand
/******************sample main loop code ************************************
  void
  setup() {
  void
  loop() {
//Name this tab: CommandLine.h
#include <string.h>
#include <stdlib.h>
#include <Meccanoid.h>
#include <L298NX2.h>
//this following macro is good for debugging, e.g.  print2("myVar= ", myVar);
#define print2(x,y) (Serial.print(x), Serial.println(y))
int chainPin = 5;
Chain chain(chainPin);
/* define modules to use and their positions */
MeccanoServo servo1 = chain.getServo(0); // first on chain  (0)
MeccanoServo servo2 = chain.getServo(1); // second on chain (1)
MeccanoServo servo3 = chain.getServo(2); // third on chain  (2)
MeccanoServo servo4 = chain.getServo(3); // fourth on chain (3)
const unsigned int IN1_A = 2;
const unsigned int IN2_A = 3;
const unsigned int IN1_B = 4;
const unsigned int IN2_B = 6;
MeccanoLed led =      chain.getLed(4);   // fifth on chain  (4)
L298NX2 G15Legs(IN1_A, IN2_A, IN1_B, IN2_B);
#define CR '\r'
#define LF '\n'
#define BS '\b'
#define NULLCHAR '\0'
#define SPACE ' '
#define COMMAND_BUFFER_LENGTH        25                        //length of serial buffer for incoming commands
char CommandLine[COMMAND_BUFFER_LENGTH + 1];                 //Read commands into this buffer from Serial.  +1 in length for a termination char
const char *delimiters            = ", \n";                    //commands can be separated by return, space or comma
     your Command Names Here
const char *setServoToken       = "setServoPos";
const char *setServoColorToken = "setServoColor";
const char *moveToken = "move";                          //Modify here
const char *setLedToken  = "setled";                     //Modify here
    getCommandLineFromSerialPort()
      Return the string of the next command. Commands are delimited by return"
      Handle BackSpace character
      Make all chars lowercase
bool
getCommandLineFromSerialPort(char * commandLine)
  static uint8_t charsRead = 0;                      //note: COMAND_BUFFER_LENGTH must be less than 255 chars long
  //read asynchronously until full command input
  while (Serial.available()) {
    char c = Serial.read();
    switch (c) {
      case CR:      //likely have full command in buffer now, commands are terminated by CR and/or LS
      case LF:
        commandLine[charsRead] = NULLCHAR;       //null terminate our command char array
        if (charsRead > 0)  {
          charsRead = 0;                           //charsRead is static, so have to reset
          Serial.println(commandLine);
          return true;
      case BS:                                    // handle backspace in input: put a space in last char
        if (charsRead > 0) {                        //and adjust commandLine and charsRead
          commandLine[--charsRead] = NULLCHAR;
      default:
        // c = tolower(c);
        if (charsRead < COMMAND_BUFFER_LENGTH) {
          commandLine[charsRead++] = c;
        commandLine[charsRead] = NULLCHAR;     //just in case
  return false;
   readNumber: return a 16bit (for Arduino Uno) signed integer from the command line
   readWord: get a text word from the command line
int
readNumber () {
  char * numTextPtr = strtok(NULL, delimiters);         //K&R string.h  pg. 250
  return atoi(numTextPtr);                              //K&R string.h  pg. 251
char * readWord() {
  char * word = strtok(NULL, delimiters);               //K&R string.h  pg. 250
  return word;
void
nullCommand(char * ptrToCommandName) {
  print2("Command not found: ", ptrToCommandName);      //see above for macro print2
   Add your commands here
int addCommand() {                                      //Modify here
  int firstOperand = readNumber();
  int secondOperand = readNumber();
  return firstOperand + secondOperand;
int subtractCommand() {                                //Modify here
  return firstOperand - secondOperand;
int setServo() {
  int servoNum = readNumber();
  int pos = readNumber();
  if (servoNum == 1) {
    servo1.setPosition(pos);
    return servo1.getPosition();
    if (servoNum == 2) {
      servo2.setPosition(pos);
      return servo2.getPosition();
      if (servoNum == 3) {
        servo3.setPosition(pos);
        return servo3.getPosition();
        if (servoNum == 4) {
          if (servo4.isConnected()) {
            servo4.setPosition(pos);
            return servo4.getPosition();
            return -1;
    chain.update();
int setServoColor() {
  byte red = (byte)readNumber();
  byte green = (byte)readNumber();
  byte blue = (byte)readNumber();
    if (servo1.isConnected()) {
      servo1.setColor(red, green, blue);
      return 0;
      return -1;
      if (servo2.isConnected()) {
        servo2.setColor(red, green, blue);
        return 0;
        return -1;
          if (servo3.isConnected()) {
            servo3.setColor(red, green, blue);
            return 0;
            return -1;
            servo4.setColor(red, green, blue);
            return 0;
            return -1;
    chain.update();
void moveLegs() {
  char * dir = readWord();
  if (dir == "f" or dir == "forward") {
    G15Legs.forwardFor(200);
    if (dir == "b" or dir == "backward") {
      G15Legs.backwardFor(200);
    if (dir == "l" or dir == "left") {
      G15Legs.backwardA();
      G15Legs.forwardB();
      delay(200);
      G15Legs.stop();
      if (dir == "r" or dir == "right") {
        G15Legs.forwardA();
        G15Legs.backwardB();
        delay(200);
        G15Legs.stop();
int setLedColor() {
  byte fadeTime = (byte)readNumber();
  if (led.isConnected()) {
    led.setColor(red, green, blue, fadeTime);
    return 0;
    return -1;
   DoMyCommand
bool DoMyCommand(char * commandLine) {
  //  print2("\nCommand: ", commandLine);
  int result;
  char * ptrToCommandName = strtok(commandLine, delimiters);
  //  print2("commandName= ", ptrToCommandName);
  if (strcmp(ptrToCommandName, setServoToken) == 0) {                   //Modify here
    result = setServo();
    if (result != -1) {
      print2("> The servo position is now at ", result);
      print2("> [ERROR] That servo ID is not connected.", "");
    if (strcmp(ptrToCommandName, setServoColorToken) == 0) {           //Modify here
      result = setServoColor();                                       //K&R string.h  pg. 251
      if (result != -1) {
        print2("> The color has been changed successfully.", "");
        print2("> [ERROR] That Servo ID is either invalid or not connected.", "");
      if (strcmp(ptrToCommandName, moveToken) == 0) {           //Modify here
        moveLegs();                                       //K&R string.h  pg. 251
        print2("> Moving motors...", "");
        if(strcmp(ptrToCommandName, setLedToken) == 0) {
          result = setLedColor();
          if (result == -1) {
            print2("> The LED module is not connected.", "");
            print2("Changing LED Colors...", "");
          nullCommand(ptrToCommandName);
But there's no errors in CommandLine.h apart from that one warning at the top of the error output. That warning isn't what's stopping it from compiling, the other errors are.
Just an FYI, the warning coming from CommandLine.h isn't what's stopping the file from compiling,
the other errors within the main ino file are.
There is a missing '}' at the end of CommandLine.h and you can't define void setup() until you end DoMyCommand().
